Safe to say I am VERY happy with this exhaust. Quiet on idle but tear-you-a-new-asshole aggressive when you open it up. This was running gate pressure of 7psi and only revving to 5k as I'm slowly working up the boost and RPM. It's so hard to not drive it like this all the time!
I love the cracks from the exhaust when you get off the loud pedal, it does it in every gear and sounds absolutely nuts hahaha!
  • Like 2
  • 2 months later...
This things isn't dead. I swear.
Flavour of the month at the moment is a weld leaking from where the fitting for the VCT was welded to the head. Nothing is able to stop it. Long story short engine is back out and head has gone away to be fixed. Will be drilled and tapped rather than getting a fitting welded on.
So just getting a general tidy up while there is no engine in the bay. Relocating power distribution block, installing castor arms (the only non standard arm in the car even after 2 years drifting haha), removing front swaybar because front wheels hit it now due to extra steering lock.
Picked up a new pair of rims to help combat the issue. 18x8+38 AVS model 5's. Love these wheels just shit sizes, will run them with a 25mm spacer on the front which should give me plenty of inner clearance.
Decided to paint some Shit too because it looks pretty average without paint. Used VHT wrinkle coat and it came out pretty good, I'm impressed.
Goes for tune (hopefully) at DVS JEZ on 16th feb and (hopefully) making its debut at Streetkarnage Halfway Hangs at RALEIGH raceway 20th feb lol. Last minute hustle come at me.
post-84937-14227870826244_thumb.jpgpost-84937-14227873283283_thumb.jpgpost-84937-14227873451897_thumb.jpgpost-84937-14227873651203_thumb.jpgpost-84937-14227873805948_thumb.jpgpost-84937-14227873966576_thumb.jpgpost-84937-14227874124231_thumb.jpgpost-84937-1422787426036_thumb.jpgpost-84937-14227874457249_thumb.jpg
Absolutely.
Just a shame I didn't think of it back in September last year when it first started leaking. Fabricator was positive he could re-weld it and it would be fine. After 3 attempts over 3 months I finally cracked the shits and said tap it.
Lend me some motivation. Guy who originally welded my head for VCT oil line f**ked it and actually cracked the head somehow and it's now leaking. Tried to fill it with JB weld and it got into the crack and now cannot be welded back up as no weld will take to the JB weld. Me having no idea about how any of this stuff works only found out right at the end when I got told the head is now not salvageable.
Right.
I said f**k it (lucky I had a spare neo head laying around) I will use my other head. So I took it to someone else who specialises in this work. Told them to weld VCT hole In bottom of head and deck flat, and drill and tap front of head for VCT fitting. They drilled and tapped in the wrong spot and now the fitting in the head only clears the intake manifold by 3mm. And that's with nothing screwed into it.
I'm well over getting assf**ked by supposedly reputable people. f**k newcastle, get me back to SA.
And f**k this f**king car.
Right.
Sound like you are having some back luck my friend. I hope everything works out for you. Subscribing for awesomeness!
I last read your build thread a few years ago when you were still in Wagga... I must say things have gone a 'little' crazy since then, with the RB30 etc!
I've often thought about putting an RB30 in mine, but always decide against it due to bonnet/stay bar fitment... How did it go in yours? Did you have to cut out the bonnet supports?
would the workshop that cocked up the head be liable for the damages he/she caused? If they know their RBs so well and they cocked it up so badly, surely they would just repair/replace the head so they don't get a bad rep right?
Go call Adam at JEM. Its a bit of a hike but Matt Gtt from the forums is a Newcastle boy im pretty sure and travels due to the quallity of work. Just google them or watch this video to get an idea :P If you email him he can also give you great advise and may know someone closer to yourself that can build the head you are looking for :)
post-84937-14233161831253_thumb.jpgpost-84937-14233161947272_thumb.jpgpost-84937-14233162086094_thumb.jpgpost-84937-14233162191554_thumb.jpgpost-84937-14233162475738_thumb.jpg
Engine is back in the bay and (pending no leaks from the fittings) it seems I may have sorted the VCT problem. More pics and write up tomorrow.
Also I wonder if anyone else can notice anything unusual with the VCT ;)
Spent all week tidying shit up and getting everything to a stage where I am happy with it.
Now it's all loaded on the trailer off to get tuned tomorrow. Hopefully 12 months of hard work and disappointment after disappointment with people letting me down come to an end and I get a decent result tomorrow!
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
