Hello Gents,
I thought I would start a discussion on shaving. A subject that is rarely spoken about yet we all do it.
Ever since the first little whisker emerged on my chin I have always shaved with multi blade cartridge shavers. However cartridge shavers seem to pull on my stubble before cutting which was quite irritating and just thought is was part and parcel of shaving.
One day I was trolling YouTube and came across a video which has changed my shaving experience. The video was about the pros and cons of the other forms of shaving:
Cartridge
Safety or DE shaving
Shavette
Straight razor
I now use a Safety shaver and have not looked back :) Not only is it a nicer shaving experience with less pulling and irritation it also works out cheaper which is a nice bonus.
So Gents what works for you? What products do you use/recommend?
https://www.sau.com.au/forums/topic/424282-shaving-and-you/
I used to be somewhat jealous of the guys who used to have to shave in highschool. Now I'm 30 and i get annoyed that i have to shave and am glad that i can get away with only shaving every 7 to 10 days (start to look a bit rough after 7). I also don't like being freshly shaven. Sweating when freshly shaven annoys me. At least on my face. Freshly shaven legs feel nice....
And i just use a cartridge razor.
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6830380
Shaving wasn't one of my favourite routines but now I treat it as some kind of "me" time.
Shaving with a Safety razor takes about 2-3 times longer than with a cartridge razor, especially with me using the brush and soap.
Generally I need to go over 3 times to get the desired smoothness.
If anyone wants more info on other types of shaving check out this bloke and his videos:
http://www.youtube.com/user/geofatboy/videos?flow=grid&view=0
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6830456
I am the same as you Dave. Shaving is annoying as all hell, but it is something that I take my time with and pride.
My routine uses two different razors. Safety razor first to get rid of the majority of the hair and thin it out. Reapply shaving cream with the brush and use a Gillet ProGlide Fusion afterwards to smooth it all out.
Do you use any pre shave oil?
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6830697
yea i towel up or splash hot water, then go over it with oil. has made a difference, feels like the blade glides over the skin easier.
i found going over the second time with the pro glide i get the smoothest shave for a couple of days.
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6830947
Best shave I ever had was when I went to a Barber and got done with a Straight Razor !! Whole experience of having someone with a blade on your throat was a little nerving at first but great!
Now i just use a cartridge and foam. Considering getting a new one as my current handle is about 10 yrs old! might give a safety razor a try as people seem pretty happy with it.
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6831137
Straight razor shaving is great, I have also had a couple if shaves done by a barber and I could hardly feel the blade shaving along my face. One day I'll step up to a shavette shaver after I get more comfortable with a safety shaver.
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6831151
I find that I sometimes get neck irritations and sometimes acne on the neck as a result of shaving, I use a multi-blade Gillete cartridge shaver with gel, I use hot water before hand and an after-shave cream.
Any suggestions?
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6831226
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
