  • 2 months later...
I have been using the AEM wideband for 6 years now, couldn´t be happier with it. Works great, no calibration needed and all the electronics fit in the 2" gauge :)
$T2eC16Z,!ykE9s7t)2UyBR-QHE0IEw~~60_12.J
I'm running the same unit in my car, and it follows exactly with the Dyno operators setup, gives the same readings, Not sure what he has though.
I personally run a NTK AFX which I bought on recommendation from reading through American forums with input from reputable big name workshops with tons of big hp cars. I was gonna buy something different for the other car but I think I'll just buy another NTK.
  • 2 years later...
I'm going to get a 20L drum, cut the top off, and then collect all the f**ked innovate LM2 hand controllers I have encountered (Including 2 of mine) pour fuel in, BURN ALL OF THE dream boats, and then with the molten plastic and slag, get f**k YOU TO HELL INNOVATE engraved on it, and post it to them.
Innovate can eat the biggest, fattest and longest of dicks.
The units last about 1-2 years. Then they go to shit. They f**k up in a shit way - the AFR reading rubber bands between 10 and 40 AFR and is absolutely f**ked. Powersupply on the car a little shit? No problems, just be an asshole and don't work at all innovate.
The analogue outputs don't even f**king work properly. they have 2 analogue outputs - one works, 0-5v the other doesn't work at all even though they boast the unit has two. False advertising.
Their customer service is ZERO
Their response to emails - ZERO
The quality of their units - ZERO
The parts availability - ZERO
f**k them.
I'm going to buy a techedge unit and never trust innovate again.
For all my CAN BUS needs on the Link G4+, I have been using hte Ecotrons ALM-CAN and ALM-CAN II. I worked with link to get templates made up so you can just load the file and it connects. I have permanently mounted one in my car over a year ago and still going good. I have installed about 5 other units, and 2 dual units without an issue. CAN is just so f**king easy. They are all 4.9 LSU too, and now with the ADV sensor.
Edited by The Mafia
My previous M800 had a controller built in for my 4.9.
Unfortunately the G4+ plug in has none so fitted a KMS eugo CAN a little xii but wtf http://kms.vankronenburg.nl/products/accessories-2/uego-can-controller/
How much was it? Always looking for good prices. And link having support for it is a bonus.
I paid 345 euro 1 1/2 years ago from this outfit. http://www.akracing-shop.de/KMS-Einspritzanlagen/KMS-CAN-Breitbandlambda-Set.html If you hunt around you may find it cheaper.
I looked at the Chinese Ecotrons one first but have been burnt before buying from there so went with this one and no complaints.
Went CAN to avoid voltage signal offsets etc.
I've been having luck with Ecotrons.
I'm with you too - I like CAN because the voltage offsets, bad earths etc give me the shits when they don't work properly.
For sure! nice to know what you are seeing is correct.
can recommend the 14 point 7.com spartan controllers using the LSU4.9 sensor. they're 75 USD for the controller.
basic, but have a 0-5v output and are cheap with automotive grade gear. haven't had an issue with mine. haven't used the sigma 2.1 controller but has a display and multiple inputs if you're into that kinda thing.
http://www.14point7.com/products/spartan-lambda-controller-2
Edited by burn4005
DO NOT USE THE INNOVATE MTX-L.
They cook sensors, then after they cook sensors the gauge will cook itself LOL
Also there are two versions of the LM2, the older is a piece of shit because it uses the old LSU 4.2 sensor not the newer LSU 4.9 found in the latest version.
I have the old croc of shit version which somehow just shows W27 most days and some days work lol.
The main reason I use Innovate is because of their serial out, which directly integrates with Adaptronic also they're the only ones on the market with a handheld wideband which I use to tune other people's cars (not so much these days, as I just tell people to install widebands before seeing me).
However, I am game enough to try the new LM2 that uses the LSU4.9 sensor.. hopefully no more wacky readings and W27 errors (also wtf is W27? it's not even in the manual)
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
