7 hours ago, robbo_rb180 said:
That is amazing work, how much of difference does this have compared to running just a flat underside?
Depends what you are referring to, the wing as a whole or just the diffusers on the bottom?
The diffusers alone are an 8% increase in total downforce compared to not having them in there and just having the flat undertray. So not massive numbers, but every bit counts.
The wing as a whole is night and day, it's about the same difference as having a rear wing compared to not having one. Ideally you would couple this front wing with a flat bottom floor and a rear diffuser, and that would be substantially better again. The regulations in Laine's class of Time Attack prevent a full flat floor though, which then also makes a rear diffuser pointless.
  • Like 1
3 hours ago, robbo_rb180 said:
Was refering to the underside diffusers, My class only allows a 50mm front splitter from body work to centre line front axle. May have to see if I can fit something into my design.
Yeh the smaller your splitter is, the more important the diffusers are. Definitely a good idea to put some in!
  • 3 months later...
After 12 months of a rebuild was so close in Dec - after a quick run in on the track at low boost we thought things were on the high end of temps when running but within range so went ahead with ramping up the power on the dyno - found a crack in the block 😌 this is prob the cause of all my dramas when I last ran
But straight into rebuilding another bottom end adding to this build
- replaced the poncams with 272 kelfords
- removed VCT
- went DBW
- added high volume adj pump - locally made from High Speed Engineering great bit of gear
Ran this back up on dyno etc etc all looked alot better this time running 15psi circa 400hp - finally back to the track for another test
Car weighed in at 1210 - this car has an extensive cage so quite heavy - this was with 40 ltr fuel
With my ce28sl on, new carbon panel from Unzipped coming this week and 15 ltr for a 3 lap sprint this should come down to 1185ish
The test was overall a success car ran really well, alot to learn to drive it properly but will get there
It threw a p/s belt in one session
fixed that and out again
Then ... burst a the front left tyre down the front straight - was a bit knarley.. managed to pull it up ok and no real damage so that was it for the night
Overall limited laps but successful and a long way to getting back to regular track time
Good to have a smile at the end of the day from driver ... and car
Edited by bcozican
  • Like 4
think it was a combination of things. Camber wear not that bad at all the tyres were only 3 events old but did sit stored for 18mths and since talking to people another major factor seems to be we started the tyre pressure too low cold which 050s are notorious for chewing sidewalls quickly when this happens. + I spose new front wing also
  • Like 1
  • 6 months later...
Alright update time
I'll 100% forget things but as lots has happened .....  summary version goes
New carbon bonnet by @Unzipped Compositeswith vents - only weighs 3kg with everything saved over 8kg in total and increased cooling
Got my own hard wired Dorian
Increasing track time to iron out issues two major issues:
1) suspension wasnt up to the task we kept hitting spliiter into the ground .... took it out sent it off to specialist tried it again didnt get the setting right in time, mm's matter !!  and broke my splitter smashing it into the ground, the fireworks from the Ti skid plates was super cool as it was at night but extremely painful for me
Got another splitter build and more / different suspension tuning - we have it nailed now this is an art in itself and learnt massive amounts!
2) even testing on Nankangs and the suspension not right yet previous to the fix we couldnt hold oil pressure through some of the corners using all good wet sump gear and ecu tricks  > so dry sump it was
Throughout this I was very fortunate to be able to pick up sponsorship from Autopro, Raceworks and Penrite
So back to the track we go for more testing - things went well
Time to turn up to wick - was running 400hp though all this banged some pounds into it
Its been a long road but we finally have put together 2 full sessions of testing / practice running. The car has run faultlessly and quickly have got a handle on it but still more to come through seat time and setup.
Already set a new PB by a decent margin on pretty shagged tyres and aiming for more
Its starting to feel worth it
And onwards we go
Edited by bcozican
  • Like 6
On 05/10/2021 at 4:23 AM, Duncan said:
great to hear it is running well, isn't it a great feeling when everything is behaving!
also, good on Autopro, Raceworks and Penrite for giving you a hand :thumbsup:
It really is... its been 2 years since I ran an event without something breaking or going wrong. Every car person knows no matter at what level or passion when your car is doing what you want it to its killer
On 05/10/2021 at 4:24 AM, ActionDan said:
Awesome!
Do you mind sharing the cost of the dry sump setup?
How do people get sponsored and how much is that typically "helping".
This dry sump setup was about 8K inc everything then its plus lines and fitting and labour - not a cheap exercise
This sponsorship and others, Ive been sponsored before when drifting ADGP by Hankook etc, has always come about by an infliction point either and incident that lead to a conversation, someone I know has recommended or similar.
One thing that has been apparent is that each time Ive been told is because I turn up to alot of events ( I do events + go to some car shows etc), I have a presentable car thats kept at a high level and its always put on the track as much as possible even when its broken I fix it and get back out there and also, Im presentable and when talking to them always talk about what they can get not when I can get. Also Im usually competing at a decent level.
.......... and then on top of that luck, as I know alot of people do that and Im not that special !
I dont put graphics on my car unless is a certain amount - I have 3 tiers of spono vs coverage I an willing to provide etc and those amounts are figures that mean something significant enough to me for me to represent someone and impact my wallet. Everyones will be different
  • Like 1
Interesting dry sump pan from PRP, quite different to the Ross one with that well in it. I've got the Ross pan and am about to do the lines now, after seeing this I wish I had the PRP pan as it looks much simpler to get it all in there. Did you end up sealing the cam covers completely or do you have a small vacuum bleed in there? Are you measuring crank case vacuum, and what sort of vac are you getting on/off boost?
Great work, the car looks fantastic.
One cam cover is blocked, the other - 12 is run from the cover all the way back to the tank at the top. The tank is vented separately
Have not measured vac etc / im sure they did something on setup as they change a spring etc but thats above my pay grade 😃
I'm running the same pump, but the Ross kit. A mate who ran a circuit RB30DET had an adjustable bleed from one cam cover, it ended up being about 4mm I think, otherwise totally sealed.
Although negative crank case pressure would be nice, I'd be happy just to keep the RB from exploding for a while longer.
Yeah few ways to do it Ive been told
Im running it as been directed by the supplier of the whole kit who has this system running on some of the biggest n best rb's in the country so I'll listen
Initially the guys putting the kit on didnt do the line back to tank just put a breather on one of the crankcase covers as they run very successful sr engines like that but in typical rb fashion it still spat oil out
Good info mate, I'll certainly talk to my fabricator about it. My mate with the 30DET had the same issue until he got the air bleed size right.
Who would have thought, an RB spitting oil everywhere - what a f**king surprise.
Got any plans for oil de-aeration? I was going to get an Oberg welded to the top of the tank similar to what the NASCAR guys do to break up the bubbles, not perfect but better than nothing. I don't know if I can stump up $1500 for a Spintric.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
