Is this build really built for response, 8.5comp and no VCT sounds more like a big boost top end setup??
How would this build compare to a RB3025 neo with VCT and 9.5comp with even 50% E85 mix... surely that would of got big torque low down...
Yes I was trying to get response and from what I had, it is pretty good. It is very linear as it goes from idle to 6500rpm, well that was the highest I could go on the revs before it played up. But when I first came home I did get the chance to give it a launch from 5000rpm and there was a little 4W spin and no lag, so I guess you can say it has pretty good response.
To get near that before I was going from 7500+ rpm and it would still dig in a bit
Have no idea about your comparisons , I am sure there will be some blokes that could answer your question :)
Has to run on 98 and you have to stop spending somewhere
Everyone would love V-cam....but cant always afford it
Lol, how exactly does VCT help response over dialed static cams when response is all you are after
Yet still yet to see any proof VCT is better then properly dialled cams
The advantage of VCT is that you can dial in your cams for response at as low a revs as possible and then still get a good push further up when your static cams would lag behind. So VCT does not of itself create better response but it enables you to set up for maximum reponse while getting better power further up than if you did not have VCT.
QED
LOL
ROFL
ETC
QED
LOL
ROFL
ETC
So what your saying is VCT does not help response against cams dialled in for response :thumbsup:
Proven !!, really, where exactly is the proof, i read alot of people saying it's better but still no ACTUAL proof
Way to be selective in what you read.....
The whole point of VCT is that you can have the (int eh case of a RB25) intake cam set for max twist down low, then have it change over to carry the torque curve further up the rev range....
But Porsche, Ford, Merc, BMW etc etc must all be wrong......
Lol, kettle black mate
The point started at someone saying built for response but don't have VCT, i posted how does VCT better static cams dialed for response then Kiwi responded basicly confirming what is said
At no point did any one mention response AND topend :/
As the guys mentioned, i have posted my graph of my stock factory RB26 more then once for people to beat for both bottom end as well as top
And i'm still waiting
We are also only talking RB25 VCT V RB26, or any other cam timing setup that only changes the inlet cam timing from one maximum to the other, though would love to see how a RB with the VE cam setup would go
ooooo.....where?
Xkalaba, don't take it as a personal attack you have to defend!
I don't like your chances of getting a guy with stock turbos chucking vct on, so I don't think you will ever get the direct comparison you are after.
What's your idle like with the dialed cams?
Spends 8k+ on VCT kit but keeps stock turbos :rolleyes:
Idles like a babies bottom, smooooth as
Not like the 34, lol
Like i said, i'm happy to see a NEO with any turbo you like, so given the NEO has a "better designed combustion chamber" and NEO and the latest tech single turbo you can get it should easy walk over my 80s tech bush bearing factory twins on a static cam setup
I want to see same boost (19psi) run 290+rwkw and beat my 26 for response then prove it on the drag strip cause we all know dynos can be made to lie
I'm starting get personal about it cause every time i come on a performace thread someone throws up should have gone NEO or VCT and saying it with no proof is misinformation
ooooo.....where?
Fark it, cause one more time won't and you asked so nicely :P
This graph was done at a SAU dyno day back in 2007 4 days after the full wieght plus stereo R32 GTR ran back to back 11.3@125mph with a stock motor, the stock turbo world record in the link in my sig
  • Like 1
I should have bought your car from the get go, would have saved me a shit load of money and hassle , haha
  • Like 1
I need to learn more, but arnt the RB26 and the neo25 pretty similar heads ( apart from VCT) , if they arnt that much different then the VCT would of been good, in comparing response im thinking about how 34GeeTee's 2.5L graph with the HTA3076 has 280kw's at 4000rpm and that doesn't even have a stroker kit...
Edited by AngryRB
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
