This is on 98 Pump
Here is the overlay of the car as it arrived.
If i hold the car at 3300rpm under load i can get 20psi.
This dyno run is seeing 22psi at 3950rpm and revving to 7000rpm in 5th gear
The Pic is an overlay of the run he did when I dropped it off (green) and today (red)
Not sure when the E85 will be done?
  • Like 2
Thats a f**ken epic result Pete!
You're gunna be in for a shock now when you drive it on Petrol let alone E85 lol!
Expect near the 500kw zone on E85 mate.. Congrats and well done to Jezzabelle and the boys sorting out the horrible mess you had! Cant wait to hear your thoughts when you drive it now!
Edited by Mick_o
  • Like 1
Yeah Mate, I knew it was a heap of shit the way it was, and I think this proves it :nyaanyaa:
I think I might start using the seat belt now :woot:
Don't forget your adult diapers as well as that seat belt!
Yeah i always knew it was POS when i saw the dynosheet let alone your impressions of how it drove!
You wont want to get out of it now mate!
So he changed the turbo rear? Good thinking
No, the PT6266 was on it all the time, it was not the PT6262 that was supposed to be ordered, this was the thing I said I would post at the end, but I waited for someone to see it on the Dyno Graph.
When I posted the pic of the 6Boost being installed I had an email from the old builder saying , oh you might notice the Turbo is a different model, I said yes it was noticed and he said that he told me about this when the build was being done, I said I think I would remember that, he said I might have been pissed, good call but that is something I would remember , well , I would think I would remember, hic hic
But all good as it is a better Turbo for the job on the 3.2 , but not for the 2.6
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
