Anywhere but centreline
One sour experience, many moons ago = Never again. No one is allowed to use that workshop on your watch.
Good thing you never went to Rajab, or the last few years of RE Customs
Centerline.... Can't go wrong. Your side of town as well.
As far as Toyota boat specialist... 612 Autoworks is a garage business doing lots of crowns, cressidas and chasers.
my preference is to take it somewhere use to dealing with cars that aren't worth about 15% of the value of my car
Ie ya standard young 'enthusiast' shop
Edited by alr33x
MaseratiOz forum is thata way --->
  • Like 1
Should I reccomend a shop that tried to BLATANTLY rip me off, and also my mate just because they work on some old POS mazda race cars?
So, as mentioned, go to centerline where they are used to working on race cars worth about 3 times as much your lexus
  • Like 1
Did good work on my pulsar a whole bunch of times and did a proper job with the Gloria.
Maybe they didn't like how you carry yourself. It's west side after all. Next to Hells Angels HQ
Well Dezz said its shit so must be shit.
Shoulda known asked in the wrong place ere
Not worried about race cars etc but I've seen how the workers treat every car the same lexus, skyline, Audi, VL I'm not interested in those places
From what I've seen / experienced:
RTR = Low by a few percent
Racepace = Low by a few percent, and not an accurate torque figure (its calculated via road speed, with no tacho input)
Chasers = Fairly Accurate
Trent = High by approx 10%
Thats why when I had an RTR tune at 255rwkw I'd tell people "255, so about 270 on trents for comparison"
At the end of the day though, who gives a crap what the figures say... What you want is a Pre-Tune overlay on the final printout so you can see the difference in the shape / area under the curve.
And lots of people always seem to forget that when you roll out of the shop, if you're actually running the same tune / timing as your max power run then your car MAY last until the end of the week, or until a slightly suboptimal batch of fuel / hot day.
RacePace usually give you a max power run just for potential then dial it back for safety; pretty conservative tunes IMO
But most tuners who have been around a long time are these days, unless customer requests every last kw - it's not in their interests to have customer cars shattering pistons
My mates car with the same mods as mine made 297kw on 98 at chasers with mine beng 10k less at trents.
We threw it on the dyno at dr drift and the afr's were 14.5 and climbing at 4000rpm when we pulled the run
Chasers CAN be good, but if they dont know you.......
That's great, you want to recommend them based on your experiences, I'll tell people not to go near them because of mine.
What kind of expert charges $X (overpriced at that) for a service, then tells that customer their setup is a mess, and asks who set it up... That's a quality workshop.
  • Like 1
Hate to break it to you dude, but they ARE all the same...
Especially a toyota with an L badge
As I said centerline work on cars worth all sorts of coin including high end race cars with rediculous suspension setups
Not really all the same big difference jumping in a 20 year old Nissan with ya dirty clothes and a car with white leather
But anyway
An apprentice driving a 10k car or a 100k car
I don't see the same same approach myself, not to mention IF something goes wrong the shitty shops will probably not even pay to fix
Edited by alr33x
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
