So shall we guess birds pi track times?
I'm guessing stock manual Toyota 86 2.05
Any further guesses?
As a comparison my first go was a 1.57 Zorst pod and a little boost, lowered springs so no castor camber adjustment...
No tune so 160ish
Got my goal of a sub 2 minute time...
How the hell do you get a 1:57 on a stock S14, and I'm 2 seconds off that with 230km/h down the main straight and AD08R and dialed in suspension?
Oh yeah, I need to learn how to drive now. :(
So while Birds and I were busy flying the SAU flag at Phillip Island, we totally missed that Alex revealed himself again to be a total f**king moron ?
Thanks again for your help with the engine troubles - she ran pretty happy for the trip home.
Jase and I noticed a blown turbo gasket too, so that was the high pitched squeal I was hearing when coming on boost. Driving on the street it now sounds like I have an ex gate :rofl:
Nice work. Yeah sub 2min is friggin solid effort. Lots of late braking and solid corner speed...
Oh yeah, my 2min 20+ was with no clutch. :P
Barnaby Joyce, while speaking to a room of ESL Chinese delegates decides to use a "battered sav" as a euphemism for low quality product.
What do we pay these idiots for again?
It gets better... clearly these people didn't know what a battered sav is, so he explains it as being part of the Australian diet. Realising he has now said the Australian diet consists of "low quality product" he back pedals by saying it's only given to people if they have bad parents.
LOL
Another English-thing the Aussies like, and known colloquially by Aussies as “savs,” saveloys are a seasoned hot dog-like sausage. They are boiled and served in a slice of bread or in a bread roll with tomato sauce. A “battered sav” is a battered saveloy which has been battered, deep fried and served with tomato sauce.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
