Pho is up there with the most overrated shit ever
This and pretty much any poor people food born out of necessity that has since been made into something of a western delicacy
I thought I'd try it after hearing all you and every other pho dick riding kunt go on and on about it... didn't even know what it was really but thought it must be alright if everyones into it so much...
was pretty much a flavorless broth that I had to add some shit to to add a slight amount of flavor
next time I went to the same place (the food is pretty tasty there so you can't blame the place), I got their other soup which has won tons in it, some meat, prawns etc etc etc, and it was f**king delicious.
When you grew up eating the cow that was shot out the back yard then frozen for 6 moths, and either frozen veggies or what you grew.
all this shit tastes good.
(but like all vietnamese food tastes much better here than in Vietnam.)
Only white people think pho is amazing.
When you grow up on Szechuan, sri racha or masala... Pho tastes like dish water.
And every Vietnamese person since the French showed them what's up
lol ok bottom feeder.
go change some oil or something.
I sincerely can't wait for the day you retards wake up. Obviously your that retarded it'll take you or one of your family members been attacked before you go err oops guess we should have cared more about who comes into our country and what they do here
Is that how you judge everyone on this planet? What they do for a job and how much that earns them?
Clearly you've known many people killed in terror attacks all around the world, no doubt people close to you. You're a close minded bigot and you know it.
Pretty much every cuisine is cool... except Australian...
lol I guess you were still in the game when upper-class pubs were trendy and every shop in the inner city sold lobster rolls
Peasants
You're all just jealous because my taste in food is better than everyone else's combined
mad jelly brah. Can we do culinary cruises starting next year so we can suss out your exceptional taste in bland food?
  • Like 2
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
