pho is soso. unless you get the beef raw on the side, and a bowl of the oil they skim off the broth and pour that right back into the soup. oh yes. then add chilli.
BUN BO HUE IS WHERE ITS AT
with lots of chilli. just spam that shit.
BBH is a close second for sure.
When I had pho in 'nam I paid the woman extra to dump a shitload of meat in there so it was effectively a swamp of meat, but at least it didn't taste like dishwater anymore
been there
turned out the "meat" was stewed cow heart tho..
with ant infested bread.
otherwise we would normally go the the local Bún Thịt Nướng place.
forget this corriander chilli or seasons, it was noodles, pork cooked in the gutter and some flavorless soup.
but we could eat for around 50c each.
so local food there was the exact opposite to local food in italy,
Your Vietnam experience looks very different to mine lol
That's probably because he didn't walk into the first bar he saw and ask for cock
went "urban exploring" last night.
unused nursing home that i wouldnt call abandoned, because the garden was well maintained, lights still worked etc.
anyway, ended up on the roof and found someone had set up some chairs haha.
awesome view of the city!
  • Like 1
so you broke in to someone's place.... you should probably post that on the internet
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
