@blah_blah, I see you lurking there...
Oh hi!
Speaking of tax time...
Monday was, 3 days after we transitioned our accounting system to Xero, a day for Payroll to do their fortnightly thing... Got an email that went to everyone saying "Please be advised that there appear to be some anomalies in the tax being withheld and the accruals if sick or annual leave are taken. This is resulting in you receiving a slightly higher nett amount of pay this week. We endeavor to have this resolved shortly, and will be adjusted in the next pay run."
Fine, I've got no issue with that...
Nekminit, my Group Certificate shows up on my desk. So next pay run is actually next financial year... Fail
LOL fail
Stuck a camera in each exhaust port and found cylinder 6 had white valves... f**k. My. Life.
So what is the ratio between driving the car and off the road like for that car so far?
5 days on 361 days off?
Vicroads to introduce cheaper alternative to club rego, known as Gregistrafion. Allows you to drive your car for the one day a year they know you'll f**k it on. Logbooks not required.
Actually you'll find my car has been doing daily duties just fine for the last 6 months!
.... so I am very interested in this Gregistrafion going forward as it'll soon be relevant to my needs
Outage of what?
My Mobile and Foxtel and Cable has been fine
Mobile data. Office wifi (Telstra) also down, but is back now
I hit the wrong switch
Have now cancelled my plans to murder whoever was responsible
  • Like 1
Birds. the spiral of skill and rerank is real once you start playing with gold novas again, sweet Jesus.
Thinking I might go down to silver 1 for lols and smurf for a bit
Need to work my way back to DMG/MGE!
Maybe we need a 5man wastelander csgo team
Edited by UNR33L
Mate you have no idea how bad silver is and how long it takes to get out of it; shit is like a prison.
You've seen I'm capable of keeping up with nova 3 at least and these fkers are holding me back. The problem is, you're coming up against teams of 5 who queue together and wanna work together, so you get placed on the "randoms" team with people who have no mics, no interest in ranking, spin/AFK at spawn or play loud music over mic...and it's pretty much up to you to win the game for them. I've lost the last 5 games since I got deranked to silver.
But happy for you to dive down into the murky depths of silver land and try to pull me out
I played cs ages ago and i still dont know what theyre talking about.
Steam sales have started. Will probably buy most of the 18 games on my wishlist. So cheap. Fark you exchange rate.
CSgo...it's cs but with ranks/matchmaking...teams of 5 where you actually work together (or are supposed to) for mutual benefit so there's a vested interest in teamwork.
what happened to the days of de_dust 32 players. That was chaos.
  • Like 1
teamwork? thats not the CSGO i know. never played ranked.
if you come to the next big Respawn LAN ill play on your team. does CSGO have support roles? lol
You can still do that, in fact there is a deathmatch mode which makes it even more chaos...so chaotic in fact that as soon as you respawn you have 5 seconds in which you can't be shot because there are players already waiting to shoot you...
It's basically a game if quick draw
  • Like 1
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
