It's in Narre Warren, but North side where there's families and very few renting bogans doing skids on your lawn in their Lexan's.
3 car shed / workshop*
Settlement is March 23 so waiting patiently.
  • Like 2
On 1/12/2018 at 12:13 AM, Odium said:
Ehhhh, can't afford any of that crap... just bought a house. Good news is, it's got room for 3 cars in the garage.
ETA for 3rd White car?
Welcome to the neighbourhood
Speaking of cars, went car shopping with the Mrs on the weekend.. she ended up buying a brand new Focus ST they're actually pretty mad value for money. 184kw and feels like good power through the whole rev range.
20k cheaper than a Focus RS, but doesn't 'feel' 20k cheaper. I guess you're paying for the 4wd and brembos on the RS oh and more power.
Anyone wanna buy a Toyota Yaris with 210,000kms?
Edited by UNR33L
You get a car, you get a car, you get a car!
I dunno I think she was mad jelly after I got a freshie she wanted one too :D To be fair she was due, her old one had 0 features, not even bluetooth, slow AF too. (Inb4 my R33 doesn't have bluetooth but i wired up a hecktick headunit etc)
Also fun fact, the colour she chose was called "Tangerine Scream" (It's yellow)
Edited by UNR33L
  • Like 1
On 1/15/2018 at 2:40 PM, Leroy Peterson said:
Oprah giving out brand new cars?
Everyone going post 2015 euro nowadays
Not moi.
2011 coz I'm poor-ish.
She has good taste in colour.
On 1/15/2018 at 1:43 PM, UNR33L said:
Pretty much the only time I'd give someone a go in the STI is in the wet :D
#playtoadvantages
ETA of TBE and tune?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
