On 12/17/2022 at 9:18 AM, Shoota_77 said:
By the way, I found the PRP turbo drain to be useless. The material is way to thin to weld.  I made my own out of 19mm stainless and associated fittings. Check my build to see what I did if you wanted ideas.
cheers mate, will do, not impressed really....
progressing pretty well.
picking up the ally tomorrow to have a crack at the cooler piping.. getting slowly better at SS the more I do (still bugger all in the scheme of things...) but ally is far more foreign... for me...
looks like the G series garrets have a spot in the front compressor housing so no need to add a boost reference in the cooler piping?!?
  • Like 4
Even the flange doesn't appear the right size for the G30, let alone the threaded fitting they supplied doesn't suit the 26 block 🤨
Yeah all sorts of shithouse!
Very nice welds, good job!
  • Thanks 1
Looking sexual mate!
And yes you can use that as the boost reference, however I've noticed big builds still reference further away down the turbo outlet pipe work.
I'm not entirely sure why, could be aesthetics?
Can't really use the hot charged temp idea because I doubt it has cooled much from compressor housing to the pipe work.
  • Like 1
cheers mate.
going to try referencing from the housing and if no good will cross that bridge later...
4 hours ago, mr_rbman said:
cheers mate.
Why are you not just using your standard plenum pre throttle reference ?
That is what is actually entering your engine.
  • Like 1
Finished the cooler piping, considering I've never really welded ally tube i was pleasantly surprised with the final results...
Still decided to paint anyway as I'm going for an all black and grey engine bay...
  • Like 2
Bought myself a new toy for xmas / birthday.
Evo V RSII.
Paid way too much for it but with any luck it certainly should never go down in value, given it's an RS it's quite rare and in surprisingly good nick.
  • Like 5
Congrats on the new toy and your welding is sensational for someone that hasn't had much experience.
I've seen welds out of workshops that look terrible and nowhere near as good as your work.
  • Thanks 1
I should clarify, haha
I am a welder by trade and have been in the industry all my working life (20 odd years) but I've been off the tools full time since the mid 2000's..
Just in case anyone reads this and thinks I've just picked up a welder and managed to pull these out my ass 🙃
  • Like 1
  • Haha 1
Thank Christ you clarified that.  I was about to drive to Sydney just so I could jump off the Harbour Bridge in grief over how bad my welds are compared to yours!
  • Haha 3
Well she's 99% complete with everything I'm comfortable doing...
I re routed the wiring to the wheel well to avoid any potential heat issues...
Leaving the mechanic to do all the turbo and wastegate lines...
My battery fell off the shelf somehow and damaged a terminal so now I got to spend more money 🙃, anyone got recommendations or hookups for a battery similar to the Optima in the same configuration?
  • Like 1
Looking real nice!
I've moved away from Optima, they aren't of the same quality as they used to be!
I now run a SuperCharge battery (made for Stop/start applications and is an AGM battery - similar to an Optima), not to mention it's an Aussie brand with 3 year warranty.
https://www.supercharge.com.au/car-battery/supercharge-start-stop-car/?post_type=battery_type&p=173
All the in-laws' cars run their SuperCharge Gold range batteries, cheap and phenomenal warranty.
  • Like 1
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
