45 minutes ago, Dose Pipe Sutututu said:
Always hook up GTS-t owners, those GT-R boys are happy with RRP and GT-R tax 😆
I dunno bout happy with it but most of us have come to terms with it! 😢
  • Haha 2
It's okay I love all you SAU members the same, in a non-homo way 😘
Hook ups for all, just no EFR hook ups because yeah nah.
  • Like 1
  • Haha 2
So I got the GTT seats in. Little bit of modding but nothing to crazy. They do sit high though which is shit as Im going to struggle wearing a helmet in the car.... But they are way more comfy. We'll see how I go might end up just changing to gtr seats 😂
Black braid is a nono for hot side plumbing, remade it with some stainless i had laying around.
Mounted emap sensor on firewall, decided to not use the copper and just do it all in hardline should look a bit better.
Plumbed up the gate and turbo as well with all new -3 braid. Need to get a couple more fittings tomorrow for the BOV and plumb that up to the intake mani. I marked out the BOV position and pulled the bumper off and cut the hole for that. Taking the car down to the shop tomorrow to be fabbed. Hopefully can knock it all out tomorrow then i'll drive it home and rip it all back apart and send to coating.
Hopefully get it back from coating in a week and then I'll put her back together and we'll chuck her on the dyno and see what sort of boost we can get out of her. And then turn it up and see what EMAP is doing (fingers crossed will take around 38-40psi).
  • Like 5
Took her down to the shop this morning and managed to get most of it done. BOV is on and plumbed up, comp cover has been tweaked along with the dump pipe. Mani welded up for the EMAP outlets and made hardline up today for it. Just need to wire it up now and we'll be good to go.
Now to pull it all back apart and get it sent off for powder/ceramic.
  • Like 2
Currently on holiday up on Fraser drinking beer and catching fish 👌
Ripped the car back apart a couple weeks ago and sent it off to be coated. Should look sweet when i get it back in. Ill pick it up on Monday when I'm back in Brissy and start putting it all back together.
Also have a new set of coilovers lined up that I'll pick up at some stage. Going to be on the hunt for a gtr diff/axle setup as well if anyone knows/is selling one.
Probably end up putting it on the rollers and setting up the staged pumps and see what boost the new manifold setup gives us. Once we're ready for power runs we'll put it on the hub and see what she will push out 💪
  • Like 4
Ordered a few goodies today. Got a Ross P/S pulley which they make for gtrs to run an r33 p/s pump with the 4pk belt so no modifying the pump and no more 3pk belt. Also got a PRP AC relocation bracket which pushes the a/c forward and jumps onto the same belt as the power steer. So it wont be overdriven on an ATI balancer and no more flicking or breaking AC belts.
Finally ordered some stuff that I need for my gearbox. Pressure sensor and a motorsport fluid temp sensor. Once I have them I'll be able to finish off my gearbox loom and have it all hooked up to the ECU and finally be able to test the dump valve out...
Ordered black heat wrap for my dump pipe too. Decided to change it up and go to black should all blend in now.
Ordering a Syltech IACV as well. Currently not running anything and apparently these new valves are pretty good so we'll see how it goes. Need to decide if I'm going to atmosphere or to the fresh powdercoated cooler pipe 🤦‍♂️🤦‍♂️
  • Like 2
Got back to Brissy on Saturday arvo. Had a nice morning drive down Fraser. Could nice photos.
On nightshift this week so went and picked up mani and pipes yesterday and spent a few hours putting it all back together. Came up pretty good, i just need to get a new radiator setup and paint it black as well 😂
Everythings back on except dump pipe and gate/screamer now. Have to wait until the heat wrap arrives that I ordered. Have new crimpers coming to terminate my pressure sensor plugs so need to wait for them before I can finish wiring emap up.
So cars not far off running, ill probably just wait until I get the a/c relo and p/s pulley before I do drive it around. Will have to dump the p/s fluid and pull the pump off so I can change the pulleys and while thats out will give me better access to the a/c compressor.
Fingers crossed everything arrives for me this week 😬
  • Like 5
Heat wrap turned up on Thursday so I got to work on Friday and wrapped the dump up. Didnt get any time to put it in yesterday, had to keep the boss happy and get her some stuff. Installed a new clothes line for her so she can dry my clothes 😂 Good for painting parts too.
Today put the gate and screamer on and plumbed all the lines and hoses back up and put her all back together 💪
Had to get a fix so went for a quick spin to see how the new mani goes. 2nd pull I saw 22psi on the dash which is amazing. Hopefully I was full throttle but definitely better than the 30psi it was before! Single gate sounds mint too. Hopefully get her on the dyno soon and give her a tuneup and get these pumps staged as well.
  • Like 6
Parts finally rocked up from Golebys after 2 weeks... Ross p/s pulley, Syltech IACV and fluid temp sensor. PRP A/C relo kit was here so started putting it all on today. Think the belt is lined up ok but we will see once ive got the P/S back on and a belt on it all.
Tomorrow I'm going to head down to mates shop and press this new pulley on and crimp my emap plug so I can finish wiring that up.
Need to find a solution to put a new p/s resi in that will take AN fittings. I think I'll weld a fitting onto the pump for the -10 line and I think ill go all the way back to the rack for the 10mm line and run a new hardline up in -6.
IACV im struggling to find a good spot to mount it that will still give me good placement to run hose for. Will look more into that once I've put the p/s and emap back together.
Then I'll be onto finishing my gearbox wiring loom. Thats going to come down to what fittings I can find that will be suitable for the job as I need to put an port adapters in for the pressure sensors.
  • Like 2
Engine bay is looking great.
I used an aeroflow resivour as has 2 ports on bottom. No need to weld fittings on power steering pump. An AN turbo drain can be used for one part with the holes elongated and there is an adapter for the other. Will get a picture of what I used on my car.
  • Thanks 1
Thanks mate!
What have you used for the line that goes to the rack?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
