43 minutes ago, Mick_o said:
What are the temperature ratings on the Festo pneumatic hose and fittings?  It looks nice and neat and definitely easy to install. But I'm a bit sceptical it would live long on the hotside there? ?
80 degrees c for the nylon fittings, reasonablysure the tube if nylon would be good to over 100 c.
If I was to use push for fittings I would use metal ones, although aerofloe also sell nylon pushfit fittings and some pretty serious cars run them for waste gate plumbing.
Cheers for the info! I think I will still remain sceptical of their long term reliability lol
  • Like 1
Same! Sure as hell wouldn't be doing that without protections for over boost setup!
I ended up going nuts and running 200 series -3 fittings there as the tube i had was breaking down and giving me boost controller issues, or so I thought.
Turns out the wires on the MAC solenoid plug had got hot and broken...
Oh well i know it really won't leak now though.
Not sure what the temp rating is for the lines and fittings. I haven't finished the build yet and will be putting heat sheathing on each of the lines to keep them from melting. My manifold, gates, and turbo also have lava wrap and blankets on them to help reduce heat.
Hello all, I have a 1972 Datsun 240z with rb26 on an efr 8474 ewg with sinco custom dual 38mm tial and 3.5” exhaust. Unopened motor r33gtr rb26, has r35 coils, prp trigger kit, 180amp alternator, elite 2500, id1050x. Hks step 1 264 cams, adjustable cam gears( not adjusted). Had my first dyno tune with the car/engine a few days ago to 415rwhp and 352ftlbs of torque on 15lbs, USA dyno, 91oct. The concern I have is the time it takes to hit full boost on the efr8474, I’m not hitting full boost until 5,500rpm (15lbs no ebc, just wastegate springs). I was expecting this turbo to hit full boost around 7-800 rpm sooner at that boost level. I have a small vacuum leak and my wideband wasn’t working are the only issues I had... is there something possibly wrong or is this rpm boost expected with my setup?
Edited by brian_s30z
adjust the cams? That's really late for 15psi but reasonable with poorly optimised cam timing.
Is your boost control soft? Holding the solenoid on while your spooling can help too.
Boost leaks don't help either
Edited by burn4005
He has no boost control.
I do have a boost solenoid but per the psi I wanted 1bar, the springs are all that’s workingboost control. Hopefully cam adjustment will do the trick, once I fix leak and o2 sensor I’ll try to dyno again. But with cam adjustment I still think I’m a bit off. I’ve read folks with 9174 with unopened rb26 hit full boost low to mid 4K rpm
rb26 swapped 240z sounds like fun!  but 1bar boost at 5500rpm is definitely not correct for 8474 on rb26.  Boost leaks are a big issue, and exhaust leak is equally likely, given how laggy the boost is coming on.  2 smoke tests (boost leak and exhaust leak) are recommended
  • Like 1
GFB DV+ T9360 is a re-circulation valve designed for OEM used BW turbos, while not officially advertised to fit an EFR by GFB, I have tested fits on an EFR.
All bolt holes align.  Plunger seal is pretty much the same diameter as the face inside the compressor housing so it seals.  Piston is workable length to be able to vent when fully compressed into the BPV body.  One slight issue is outer seal on compressor housing doesn't sit in factory grove but still sits on a flat surface on the compressor housing
Edited by RB335
12 minutes ago, brian_s30z said:
Checked my ignition timing and it was on 10btdc. The haltech has it on 10degrees too. Tuner is going to verify and fix, hopefully that is the reason 8474 is coming on late
There's nothing  to fix. They need match between ecu and light, that's all. They do match.
  • Like 1
27 minutes ago, brian_s30z said:
I thought is suppose to be set at 20btdc..?
With the haltech (and other ecus) all that has to happen is they match. Can be any number you want with an ecu that you can lock the timing to that chosen number. Change it to 20 in the haltech and chech with gun, it will be on 20.
  • Like 1
Yes. And no. What Ben is trying to say is that the sync timing is not the idle timing.
Manuals (RBs) should idle at 15°. Many of the autos idle at 20° because it makes them have a little more torque at idle which is needed to keep the engine working against the load of the torque converter.
The sync timing just means that the ECU knows what the actual engine angle is. The actual timing that is run at any moment is then simply what one table or another in the ECU demands. 4000rpm and 20 psi of boost? Likely to be about 20°. That's 20° exactly, because the ECU knows where zero is (because the ECU was told where 10° was).
  • Like 1
Hi all. I’m currently installing my EFR7670 setup on my R33 GTR and have some questions on finishing it up
  1. Should i route the water feed line from the feed line coming from the back of the engine and T to the block, similar to the stock turbos setup? Can I just do the water feed from the block near cylinder 5 without having to bring in the rear line from the other side of the motor?
  2. Should I follow BW’s directions and plug the water feed on the bottom side and water return from the top side of the turbo?
  3. What’s the max boost I should consider? I know it runs on the smaller side but want to avoid over spinning the turbo (it’s a EWG 1.05 AR)
Edited by cachorro
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
