r34 GTT brake upgrade
Hi Guys,
I have set of EBC 310 grooved and dimpled on my r34GTT
I installed it with ebc red stuff and I have to say brake performance is fu***ing sh*t
I think my kia picanto 1 liter is better than the skyline. I also changed the fluid to dot4 racing from castrol.
My hope is that I need to bleed the system and brake is ok. I have been lazy to do it as have hardly drived the car but I am using it frequently now.
I almost crashed it another day by failing to stop. it gets very soft and goes further down when braking hard .
Anyways, whilst I am going to do the bleeding , I thought I also change the caliper and rear discs to groved/dimpled.
It is the standard size of 310 at front and 295mm at back. would you invest £600 on pair of GTR brembo or change the disc to 350mm and get evo10 caliper and disc?
I spent in excess of £400 on the disc and the pads last time.
  • Like 1
https://www.sau.com.au/forums/topic/466946-r34-gtt-brake-upgrade/
1 hour ago, stranger12 said:
That is the typical answer!
i have and been searching, i have seen evo10 355 may fit
has anyone done it?
If you have been searching why are posting in the forced induction section instead of "suspension, braking and tyres" where there is a whole sticky on brake pads and the first post is on R34 GTT brakes? And a free tip - use Google for searching this site... and do the research before you spend the big bucks rather than after.
User error.
No way you're even going past the GT-t braking capabilities on the street. Many people use the same setup on their track cars and they seem to stop so there's no way you can possibly exceed their capabilities on the street.
Hey if you're keen on frying cash and funding any reason to do so, then that great but if you can't get a set of 310mm brakes to work then even a set of 350mm Evo brakes won't save you from installation error.
  • Like 2
I understand but I want to fix the brakes and ensure it is capable of stopping a 300rwkw car so hence the reason for my post
I was thinking to get gtr brembo caliper which are quite expensive
evo calipers are cheaper so I think it is a wise investment to change caliper and discs to evo 10
would i gain 25-30 braking power compared to original skyline?
Work out the current problem before going and wasting more money. Good pads, rotors, fluid and braided lines will stop a 300kw car no worries at all as long as they have been installed correctly
I upgraded the puny brakes on my heavy 320AWKW  Stagea  with GTT brakes and it was perfectly adequate on the street and even on the track for the first few laps. I only replaced them later for the track - would have been fine for street use.
Buy proper pads and discs, I owned EBC stuff too but for an S13 and OEM pads are way better than EBC shit. Rotors doesn't seem to be any better, they are way too hard so they just heat up and warp instead of slowing down the car.
cool, how do you guys bleed it using abs module ?
I don't have a software that can activate it , I normally bleed, drive for few hundred miles and bleed again in hope of all air from abs is bleed that way
I went ahead and bought set of evo 9 brembo calipers, it was £450 for two calipers rebuild plus red stuff pads
it looks cheap to me, how can I ensure it is actually evo 9 calipers and it is brembo ?
The brembo logo seems to be a paint only so anyone can fake. The guys claims he has also changed all of the pistons
http://www.ebay.co.uk/itm/262612438947?_trksid=p2060353.m2748.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I can cancel it if it seems fake to you guys
Edited by stranger12
No idea whether or not they are genuine but as about 4 or 5 people have told you there is nothing wrong with GTT brakes if you bleed them properly and use some decent pads. if you go to the brake forum you will see info on how to bleed your brakes properly (needs two people for best results).
Are u getting a larger master cylinder to go with the larger calipers? Are u also getting larger discs ? They won't b any good if they r not installed correctly again.
Have u even taken it to a proper mechanic to even have a look at your problem?
yes I am getting bigger master cylinder later.
I just want to improve it now and know my brakes can break my neck if needed :)
I do everything on the car myself and know it needs bleeding but hardly use the car and now want to change it anyway for above reason
I will then change the backs to 350 as well in the future
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
