r34 GTT brake upgrade
Hi Guys,
I have set of EBC 310 grooved and dimpled on my r34GTT
I installed it with ebc red stuff and I have to say brake performance is fu***ing sh*t
I think my kia picanto 1 liter is better than the skyline. I also changed the fluid to dot4 racing from castrol.
My hope is that I need to bleed the system and brake is ok. I have been lazy to do it as have hardly drived the car but I am using it frequently now.
I almost crashed it another day by failing to stop. it gets very soft and goes further down when braking hard .
Anyways, whilst I am going to do the bleeding , I thought I also change the caliper and rear discs to groved/dimpled.
It is the standard size of 310 at front and 295mm at back. would you invest £600 on pair of GTR brembo or change the disc to 350mm and get evo10 caliper and disc?
I spent in excess of £400 on the disc and the pads last time.
  • Like 1
https://www.sau.com.au/forums/topic/466946-r34-gtt-brake-upgrade/
1 hour ago, stranger12 said:
That is the typical answer!
i have and been searching, i have seen evo10 355 may fit
has anyone done it?
If you have been searching why are posting in the forced induction section instead of "suspension, braking and tyres" where there is a whole sticky on brake pads and the first post is on R34 GTT brakes? And a free tip - use Google for searching this site... and do the research before you spend the big bucks rather than after.
User error.
No way you're even going past the GT-t braking capabilities on the street. Many people use the same setup on their track cars and they seem to stop so there's no way you can possibly exceed their capabilities on the street.
Hey if you're keen on frying cash and funding any reason to do so, then that great but if you can't get a set of 310mm brakes to work then even a set of 350mm Evo brakes won't save you from installation error.
  • Like 2
I understand but I want to fix the brakes and ensure it is capable of stopping a 300rwkw car so hence the reason for my post
I was thinking to get gtr brembo caliper which are quite expensive
evo calipers are cheaper so I think it is a wise investment to change caliper and discs to evo 10
would i gain 25-30 braking power compared to original skyline?
Work out the current problem before going and wasting more money. Good pads, rotors, fluid and braided lines will stop a 300kw car no worries at all as long as they have been installed correctly
I upgraded the puny brakes on my heavy 320AWKW  Stagea  with GTT brakes and it was perfectly adequate on the street and even on the track for the first few laps. I only replaced them later for the track - would have been fine for street use.
Buy proper pads and discs, I owned EBC stuff too but for an S13 and OEM pads are way better than EBC shit. Rotors doesn't seem to be any better, they are way too hard so they just heat up and warp instead of slowing down the car.
cool, how do you guys bleed it using abs module ?
I don't have a software that can activate it , I normally bleed, drive for few hundred miles and bleed again in hope of all air from abs is bleed that way
I went ahead and bought set of evo 9 brembo calipers, it was £450 for two calipers rebuild plus red stuff pads
it looks cheap to me, how can I ensure it is actually evo 9 calipers and it is brembo ?
The brembo logo seems to be a paint only so anyone can fake. The guys claims he has also changed all of the pistons
http://www.ebay.co.uk/itm/262612438947?_trksid=p2060353.m2748.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I can cancel it if it seems fake to you guys
Edited by stranger12
No idea whether or not they are genuine but as about 4 or 5 people have told you there is nothing wrong with GTT brakes if you bleed them properly and use some decent pads. if you go to the brake forum you will see info on how to bleed your brakes properly (needs two people for best results).
Are u getting a larger master cylinder to go with the larger calipers? Are u also getting larger discs ? They won't b any good if they r not installed correctly again.
Have u even taken it to a proper mechanic to even have a look at your problem?
yes I am getting bigger master cylinder later.
I just want to improve it now and know my brakes can break my neck if needed :)
I do everything on the car myself and know it needs bleeding but hardly use the car and now want to change it anyway for above reason
I will then change the backs to 350 as well in the future
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
