Heads-up...its time to put it all together!
A Cometic MLS head-gasket is sandwiched in-between & now its time to finish it offIMG_9084.thumb.JPG.8e0ebcfedd0bbf22883fbd352678c50d.JPG
All assembled & ready to go - a cheeky ASR extended sump has also been given a new coat of paint & will hold 6.5ltrs of oil :)58e0ad20f346e_IMG_9088(noexif).thumb.jpg.3a50baaf2ea5787db0fb040d828ee0f4.jpg
Next steps are:
- Transfer the Alternator, P/S pump, Aircon compressor from the old rb20 & fit the shiny gtx3071.
- Remove the rb20 & gearbox and make space for the Neo and Rb25 gearbox which will be popping inside.
- Work out the wiring
Still so much to do....
  • Like 3
If your willing to spend the dollars I would get this for the wiring side
http://www.wiringspecialties.com/rb25-neo-wiring-harness-r32-gts/
Will do everything you need it to do, I also have all the wiring info somewhere on a hdd so let me know and ill pass it on
  • Like 1
Quick update on my growing stash of goodies ready to be installed :D
  • Garrett GTX 3071 gen2 - Provided by GCG Turbochargers
  • Nismo GT LSD 1.5way - Provided by Jesse Streeter
  • Nistune ER34 board with Stagea basemap - Provided by Nistune
  • Walbro 460L/h ethenol fuel pump - Provided by Scotty's Customs
  • Xspurt 1000cc (shot long nose) injectors - Provided by Scotty's Customs
  • Defi gauges - from facebook
  • Splitfire Coilpacks - from facebook
more to come...
  • Like 5
oooo ooo yummy, curious with your NEO what oil restrictors did you use? I've read the NEO block already has decent restrictors from factory and there's no need to run smaller.
1 hour ago, iruvyouskyrine said:
Neo has single 1.3mm from memory (was like 3 years ago). I put single 1.2mm in my 25/30 Neo.
I read someone said 1.27mm which is pretty much 1.3mm.. I should be good then :)
Running OEM :)
No big news - been trawling through blurry wiring diagrams for the r32 to prepare for the massive job of wiring in the rb25 neo.
I have heard stories of people losing power-steering when doing such conversions and I tried to get to the bottom of this...
It looks like the HICAS ecu controls the electronic power-steering solenoid.
This solenoid is driven by Speed-input; at low-speed there is more power steering assistance & at high speed its reduced.
It looks like the HICAS ecu requires 3x inputs - Speed, Tachometer & Neutral.
As long as those 3x inputs are still supplied to the HICAS ecu, then there should be no issues with Power steering! (fingers-crossed)
Not sure where these 3 inputs splice under the dash or next to the ecu...will need to follow some wiring within the car & see where they lead..
Hope to create my hybrid r34/r32 engine-loom this weekend - some further reading is still required.
  • 3 weeks later...
On 5/5/2017 at 1:43 PM, DaymoR32 said:
anymore updates on the hybrid loom?
Still working on it - have managed to map each wire on the Neo F3 plug as well as the r32 body plugs. Will attempt this weekend on the hybrid loom.
For those playing at home, found an easy method to repin the Neo F3 plug here -
  • Like 1
  • 3 weeks later...
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
