Heads-up...its time to put it all together!
A Cometic MLS head-gasket is sandwiched in-between & now its time to finish it offIMG_9084.thumb.JPG.8e0ebcfedd0bbf22883fbd352678c50d.JPG
All assembled & ready to go - a cheeky ASR extended sump has also been given a new coat of paint & will hold 6.5ltrs of oil :)58e0ad20f346e_IMG_9088(noexif).thumb.jpg.3a50baaf2ea5787db0fb040d828ee0f4.jpg
Next steps are:
- Transfer the Alternator, P/S pump, Aircon compressor from the old rb20 & fit the shiny gtx3071.
- Remove the rb20 & gearbox and make space for the Neo and Rb25 gearbox which will be popping inside.
- Work out the wiring
Still so much to do....
  • Like 3
If your willing to spend the dollars I would get this for the wiring side
http://www.wiringspecialties.com/rb25-neo-wiring-harness-r32-gts/
Will do everything you need it to do, I also have all the wiring info somewhere on a hdd so let me know and ill pass it on
  • Like 1
Quick update on my growing stash of goodies ready to be installed :D
  • Garrett GTX 3071 gen2 - Provided by GCG Turbochargers
  • Nismo GT LSD 1.5way - Provided by Jesse Streeter
  • Nistune ER34 board with Stagea basemap - Provided by Nistune
  • Walbro 460L/h ethenol fuel pump - Provided by Scotty's Customs
  • Xspurt 1000cc (shot long nose) injectors - Provided by Scotty's Customs
  • Defi gauges - from facebook
  • Splitfire Coilpacks - from facebook
more to come...
  • Like 5
oooo ooo yummy, curious with your NEO what oil restrictors did you use? I've read the NEO block already has decent restrictors from factory and there's no need to run smaller.
1 hour ago, iruvyouskyrine said:
Neo has single 1.3mm from memory (was like 3 years ago). I put single 1.2mm in my 25/30 Neo.
I read someone said 1.27mm which is pretty much 1.3mm.. I should be good then :)
Running OEM :)
No big news - been trawling through blurry wiring diagrams for the r32 to prepare for the massive job of wiring in the rb25 neo.
I have heard stories of people losing power-steering when doing such conversions and I tried to get to the bottom of this...
It looks like the HICAS ecu controls the electronic power-steering solenoid.
This solenoid is driven by Speed-input; at low-speed there is more power steering assistance & at high speed its reduced.
It looks like the HICAS ecu requires 3x inputs - Speed, Tachometer & Neutral.
As long as those 3x inputs are still supplied to the HICAS ecu, then there should be no issues with Power steering! (fingers-crossed)
Not sure where these 3 inputs splice under the dash or next to the ecu...will need to follow some wiring within the car & see where they lead..
Hope to create my hybrid r34/r32 engine-loom this weekend - some further reading is still required.
  • 3 weeks later...
On 5/5/2017 at 1:43 PM, DaymoR32 said:
anymore updates on the hybrid loom?
Still working on it - have managed to map each wire on the Neo F3 plug as well as the r32 body plugs. Will attempt this weekend on the hybrid loom.
For those playing at home, found an easy method to repin the Neo F3 plug here -
  • Like 1
  • 3 weeks later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
