4 hours ago, Adzmax said:
I picked up an R200 with a 4.4 LSD on the weekend, I'll strip this down and rebuild it along with the rest of the rear end in the coming weeks.
7 Days for a update bruh, whats happening :P
In all seriousness, take your time, build is looking awesome :D
7 hours ago, jmknights93 said:
Such an awesome thread. Loving these updates :)
Thanks mate!
Some goodies we purchased in Japan at Nostelgic 2 Day arrived today (no pun intended), a set of S.E.V Marchal headlights.
  • Like 2
It's been a pretty crazy few weeks so not a lot happening on the car front, hoping to reassemble and pain the GTR grill this weekend though. I can't for the life of me find the paint sample we made up so I had to get a mate to send me down his colour chips for matching, no paint codes available for this stuff unfortunately.
I was going though some boxes from my trip to Japan in Feb this year and found these goodies. Some door handles, a GTR style gear know, NOS badges, water heater seal and stainless trim for the centre console.
Also a whole bunch of stickers for the car, it's the little details that make the difference! :)
  • Like 2
So a pretty major development this week, Lachlan Fowler at Les Collins Racing had a fully built 3.3ltr L series short block for sale which I've purchased. He's decided to go down the full billet crank race spec path meaning the built bottom end is no longer needed. I'll supply my own P90 head to the builder to be ported, polished and rebuilt. The motor should be good for 350hp and 280ft'lbs of torque with the right head, cam and induction.
Short motor specs are:
  • L28 3.3ltr short engine.
  • 89mm bore x 89mm stoke = 3322cc
  • Engineered by Les Collins
  • F54 block. Acid dipped, 1/2 grout fill, sonic tested & offset bored to 89mm & finial diamond honed to exact clearance.
  • Deck milled parallel to crank tunnel centreline.
  • Clearanced crankcase, de-burred & painted in Gyptal.
  • New gallery plugs. Blanked oil pressure relief port.
  • Standard sump & pickup (to be replaced with Kameari pickup)
  • Modified 89mm stroke crankshaft, oil gallery plugs tapped & plugged.
  • Custom CNC billet steel 8.8kg flywheel to suit crank (no clutch assy).
  • 137mm I-beam connecting rods with ARP2000 rod bolts.
  • Custom SPS 89mm forged pistons – designed to work with a P90 head.
  • New timing chain guides & new Kameari HD timing chain.
  • New OEM front timing cover (de-burred, polished & water-jet blasted) fitted with replated bolts.
  • New Water pump.
At this stage I'm looking towards injection as the 44 Mikuni carbs I have just wont be big enough and would limit the motor to around 280hp. The other option is 47mm OER carbs but Jenvey make a 47mm heritage DCOE twin body with the injectors hidden in the body. Heritage look with modern features. I'll need to look at a fuel tank conversion using EFI hardware's EFI conversion kit and consider an ECU, perhaps Motec M800 or a Haltec equivalent.
Not sure who will complete the head work and engine but at this stage I'm looking at either Peter McDonnell or Les Collins Racing, both are true professionals and will do a great job.
Here are some shots of the motor before it will be torn down:
  • Like 2
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
