Surplize modapuckers lol
This happened today, driving back from work like a normal person. Doesn't happen when I drive like a complete knob, or launch it at 4k.
Anyhow tried off and turning it off and on, that didn't help ?
20190927_182351.thumb.jpg.89d2e9fbac9571962b60dbe4603e8d16.jpg20190927_182355.thumb.jpg.5b249c4220d6e9f137a7d4c7b2e7435f.jpg
So headed out to pick up the missus in this shit box, and spanked the limiter, she didn't like it.
  • Haha 1
1 hour ago, r32-25t said:
Typical German car
Lol yeah but considering it's not even 1.5 years old with 17xxx kms on it, it's a joke!
Modern German cars have a system built into the BMCs and CAN that turn on one of a set of random errors each 18 months for the life of the car to ensure you get rid of it and buy a brand new one just after warranty finishes.
  • Like 1
  • Haha 3
It’s why as cool as I think the golf r is I’d never own one, I’d look at either an sti or the Hyundai i30N
  • Like 1
Man my back is sore lol. A fixed bucket seat, semis, several solid suspension arms, rock hard suspension but yeah ended up doing over 450km today. 1.5 tanks of fuel later ?
Good drive with @PLYNX and my mate in his R33.
Okay, admittedly it was pretty fun and first time I've actually stretched the new setup with a lousy tune. Shoots flames, 11:1 afrs, lazy 10 to 12 degrees of timing but it is wanting to light up 255 Nankang AR-1 semi slick tyres. Still need to swap out thr gate spring to a softer spring, running a 4 port solenoid and with a 1bar spring there's very limited resolution, kept spiking and hitting engine protection.
  • Like 7
I'm sorry I missed the run.
I've spent the day yelling at people and driving back from sunny Singo
Glad your beastie got to stretch its legs.
What's next for the 33, back in the garage for a spell?
Umm no idea to be honest, I said I'll try go once a month with @PLYNX but knowing my life, even that would be hard to achieve.
And here's a dose video and some gate, wallah swear to god I didn't use the photo illegally (didn't talk or text or use social media) lol
  • Like 2
43 minutes ago, Murray_Calavera said:
What spring are you planning to swap to and what max boost are you chasing?
0.5 bar and will run up to 2 bar.
At the moment trying to command 1.3 to 1.4bar is very challenging. Every 1% to 2% change in duty cycle is jumping 0.1 to 0.3 bar of boost. By dropping the spring you end up with higher resolution. Just some idiosyncrasies with running a 4 port. Running a 3 port but across both ports on the gate is a simpler solution which allows decent control too, but I wanted to try out a 4 port setup, so here I am lol.
1 hour ago, ActionDan said:
Can't for the life of me think why it would be showing signs of fatigue or damage ;)
Well it's there to use right? lol.
1 minute ago, ActionDan said:
"The brightest candle burns twice as fast"
That's why people run boosted engines, to get twice the atmospheric pressure :)
Another solution I've come up with for another car I tune which granted, we've not tested yet - and I don't know how flexible the Halaltech is with settings and available outputs, but we're running 2 MAC valves and running one of them against a fixed PWM look up table to "bring up the base pressure", then use conventional boost control to drive the second one as an effort to retain 3-port style table granularity but give a 4-port style boost range.
Interesting, is that similar to how anti-phasing works? I hear that terminology thrown around a bit however given we aren't in race cars or F1 cars I've never bothered to read further nor investigate further.
4x port was already going into another level for me haha...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
