What a day, been moving shit to the in-laws, cleaning the house, mowed lawn, planted a bunch of flowers. Then sorted out shit box for tomorrow, bleed brakes, installed new Intima pads (test compound), loaded up car with shit and ready!
Rotors look a bit cooked, I managed to crumble the Intima Type-D v2.0.
@iruvyouskyrine they're 57S :)
  • Like 1
Dose knows I'm good for the $$
I've had to pay him for his services before.... ?
Rotors do look average.
Edited by ActionDan
Motor seized heading back to Sydney. Had full oil pressure, no over heating.
Was tapping a bit on the way home but just thought maybe lifters.
Car did hit the engine protection a few times on the track though for low oil pressure around big bends.
Now waiting for my mate to come back with a trailer on the side of the Hume Highway.
Yay?
  • Sad 7
Cheers @Duncan!
Luckily just at the on ramp to Sydney out of Sutton Forest Maccas, safe-ish spot.
Same tyres lol..
My mate did a 1m10s in it, I managed only 1m12s
well, you can't change the laws of physics; a borrowed car is always quicker than one you own.
at least it is a short walk to heatherbraes (or Maccas if that is your thing)
  • Like 2
I did crack 196 km/h down the main straight but bitches out just as the barrier stopped.
Could have possibly gone 200 km/h+
  • Like 1
Is what it is lol..
Maybe the few times the Haltech went into engine protection was a sign I should not full send it around bends on noise.
19 minutes ago, Dose Pipe Sutututu said:
Is what it is lol..
Do you have logs of the sessions where the engine protection kicked in?
I'll download them sometime during the week and we'll find out.
6 minutes ago, robbo_rb180 said:
That sucks, dry stumped billet rb30det with Samson time?
Hopefully damage isn't to bad and just needs machine work and bearings.
Haha I'm over it man, maybe new car time ?
Get that part out sale going and find a 335i coupe.
  • Like 1
Well shit ?
This is legit the 7th RB I know of thats seized this week. Just as I get my block back from the machinist. Its like the world is screaming at me to stop what I'm doing.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
