40 minutes ago, ActionDan said:
Where can I get one?
https://burubado.com/collections/stickers/products/please-do-not-abusing-of-the-motor-sticker
Could ask for foil sticker, so it's like the one pictured
Lockdown dis dat, anyhow after 3 months of shit just sitting in boxes I decided to do something.
Probably the last time I do something for a while too, my back is sore and my hands are dirty now 😅
Was on the market looking for a used one, wow.. people are wanting like $300 for an used condenser, ended getting a new one for $650.
  • Like 2
14 minutes ago, Unzipped Composites said:
Haha... I threw my condenser in the bin when I stripped the car down, imagining that second hand they were worth 3 cents and a mouldy apple core.
It's covid tax, it has ruined the JDM market.
Long gone are the days of running R33 S2 for $5k to $7k 😔
That's why I chose to go to town and respray and send its mum.
  • Like 1
14 hours ago, r32-25t said:
Where did you get the condenser from?
Amayama, worked out cheaper than local because I bought a bunch of stock seals, gromets, interior bits and bobs.
Vega Motorsports guy has them for GT-Rs at a reasonable price.
Just had a look at r32 ones are almost $1200 😞
  • Sad 1
Can we get thread back on track please.
How are you sydney carnts getting 22c feed in tariff, im in newcastle and did the ring around to every company last year and the very best i was offered was 12c. My solar is about 6 years old now though, are you only getting such a good rate because you got Origin to do a complete solar install?
I can't even imagine getting 50+c a kWh lol
Have a look at AGL, apparently they're doing 20c for the first year!
I'm only getting 22c FIT because I'm going with Origin's Solar system (which is overpriced compared to others, but the only way to get the 22c FIT).
17 minutes ago, ActionDan said:
I just got an email saying I can no longer get 10.2 it's now dropping to 6.7... what the f**k.
Time to go shopping!
Yeah I will, hard in Vic, they all vary so much.
The current mob does a 69c day charge and off peak rates all weekend 😕
In good news, I have found some used Tigo's going cheap :)
  • Like 1
Update, here's a full day's worth of data. Pretty nice sunny day, barely any clouds in the sky.
6.6kW system with 17x 390W JA Solar panels (cheap shit) and a 5kW GoodWe inverter (also cheap shit). Origin didn't really have flexibility with their package choices but after reading into it and also the warranty plus Origin's guarantee of craftsmanship I was sold, especially with the 22c FIT.
We have a North facing double storey house with a colorbond roof. Means theoretically we would get better sunlight coverage.
@PranK what is it with these 250px max width thumbnails? Lol.
1233411653_Screenshot_20210704-222920_SEMSPortal.thumb.jpg.6c4c3765e9769a830d1570eabbffe370.jpg
  • Like 1
would be great if there was a newer nissan you could buy the bits from. i need the whole AC assembly apart from the bit under the dash essentially. im looking at a fortune if i want AC back in my car (which i do)
  • Like 1
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
