Clutch upgrade
Hi all
i am deciding on my clutch to support my max 500 bhp at flywheel.
i have seen numorous brands, what brand will you pick or well known?
would you also install a lighted flywheel?
i have seens clutches from stage 2 to 4.
is there any harm in installing stage 4 if I don't need it?
i think stage 4 is 500 bhp and above
finally would you have a go yourself to replace it? Is it a tough job if you are one man ?
i was thinking i could get a transmission support
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/
This isn't need for speed, ignore the whole stage 1,2,3 crap
Call NPC Performance clutches. Aus made (use some exedy stuff) and do a good product. I have their lightned flywheel and 10" sprung button clutch in my car, had it for years and has always been great, pedal feels resonably light
They also do a twin plate if you want to go all out
  • Like 1
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7800986
Please Google first and then post here if you still need more help. Usually Google will point you to a number of SAU posts as most subjects have been exhaustively discussed over the years...e.g.
which clutch for modified Skyline
or...what clutch for 300kw RB
or.. how to replace clutch on Skyline R34
etc
also scroll down to
Tutorials / DIY / FAQ  and see what help is available there.
Warning: doing a clutch by yourself can be dangerous so read all the instruction carefully so you don't get pinned by the car or have a gearbox fall on you !
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7800988
1 hour ago, stranger12 said:
I looked at exedy and extreme but again some dealers sell it with stages attached hence why i asked
Nobody who knows anything about clutches uses the word "stage".  Same with cams.  The only thing that comes in stages is the mail in the wild west, 175 years ago.  Oh, and nitrous.
  • Like 1
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7801009
Stage 3 nitrous or 3 stage nitrous?
:D
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7801099
Sorry to jump in this topic like this. Does anyone know what power rating a nismo 30210-RSR40 clutch kit is rated for rb25. Maybe this would also be good for his application. I have one sitting here but have no idea what power it can handle.
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7803987
From GTR UK:
Standard Nissan cover produces 900 KgF Clamp force
Nismo 30210 RSR40 produces 1050 KgF
Nismo 30210 RS581 produces 1200 KgF
https://www.sau.com.au/forums/topic/468306-clutch-upgrade/#findComment-7804000
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
