This is some result form an ATR43SS1 Turbo in bush bearing. It made 227rwkws @ 17psi on Pump 98 fuel. I've used the same turbo with BB core on my R34.2  with an RB20det (running with melted cyc 6) which is very responsive.
Green boost curve: Same turbo with BB's core.
15589628_10154306680648865_5979545858977
About 2 months too slow Tao, I asked if you were going to continue with testing on RB20 and you said it was too much hassle for little gain with all the problems you were having. Ended up going with an EFR6758.
Third pic isn't loading for me either btw
  • Like 1
So around 900rpm improvement in response from BB core??
Is that a typical result??? seems like a lot
*Sorry, should be in hypergear thread
On topic, can't wait to hear it with that manifold! Would like to change the manifold on mine, but cant pull the trigger cost wise, just for the noise. If I could justify a jump in performance aswell, I could maybe do it, haha
Hitting 15psi by 4000rpm (picked that because the curve to 17psi rolls over a little presumably because of boost control so saying full boost at 4700rpm makes it sound much worse than it is) and making 227kw @ hubs, which is a healthy result - but to be honest, it may be my 16G fanboism coming out but I feel that one of those would happily do that power on 98 too, but with significantly better response.   His ball bearing equivalent shows 18psi by 4000rpm, which is more like what I'd expect from the 16G but of course DBB also offers transient response improvements (the old "Dyno doesn't show it" stuff) so that sounds a bit like it'd be quite a nice turbo on an RB20, especially if it's not expensive.
Either way, neither turbo are twin scroll - let alone EFRs, so probably a bit off topic here.
Edited by Lithium
Might be 6 years too late. The date on that graph says 2011, lol.
:D yes thats when they were first developed.The turbo is ATR28SS15 based, it maxed out at 281rwkws P98 fuel on an worked SR20det, on a stock cammed Rb20det it should be maxing some where towards the 250rwkws depending on mods.
I bought a R32 GTS4 late last year and trailed a bunch of other wheel and housing combinations and that is still the best one, BB improved transit response and made the turbo came in with very light throttle movement. Unfortunately I've picked up a bad car, its unfit for the building purpose, I might get another one to continue this venture when I see something come up decent.
Keen to hear more about the intake manifold and any dramas fitting it up.
I've got a complete RB26 intake, throttles etc and adapter plate sitting here waiting to go, just need an RB30 thermostat housing.
It will be replacing my current FF manifold so I'm hoping not too many gotchas.
I'm using the otaku garage adapter on mine. They fit fine on RB25 but on RB20 there is only a bees dick of clearance to the Thermostat housing. You actually have to scallop the coolant rail that runs under the 26 manifold to make it fit, and even then doing that will be a tight fit.
I have some pics of it but they are on my computer, will post them up here when I get a chance
#twinscrollislife
You planning to ceramic coat or wrap that manifold?
Neither, it's far too beautiful for that! It should go purple and gold being the hypertune 347ss. If it starts to fade or look shitty after a couple of years I will ceramic coat in titanium.
Nope wasn't me, I live in the land of the harshest vehicle laws in the world (aka straya)
I'm yet to try it as I have been away from the car for 4 weeks but will be getting stuck into it when I get home. I will keep this thread updated for you to follow [emoji106]
  • 1 month later...
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
