On 7/12/2017 at 10:32 AM, Sack87 said:
 I picked up 7psi of boost without touching a thing, so it's stuck on 21psi with standard injectors and pump. I've hit up Christian to see if it's possible to run the car safely at this level on 98 with his flash tune, otherwise I will probably put a hi-flow cat in to drop the boost a little.
LOL LOL LOL what would Christian know!!! and why would you trust his flash tune meant for a different motor HAHAHA
Firstly your not making any power over 16PSI (on a stock turbo) as the turbo cant flow that much air your just producing extra heat.
Go see a real tuner and put the car on a dyno before you punch Piston #6 out of the block like the rest of you new age Stagea owners
and put a 100cell cat on the thing FFS
  • Like 1
And you know everything I assume, including how to hack and tune a factory Ecu?
Firstly I'm running a Billet Intense RS Turbo and secondly it's safe on 19psi as my AFR doesn't go above. 93v at WOT.
And it's "you're" by the way.
  • Like 5
  • Haha 2
  • 1 month later...
3 hours ago, Ben C34 said:
Does that actually achieve anything? Or just theoretical?
No idea haha, most probably not but it cost me nothing to make.
The more the better theoretically. I wanted to make up one that picks up several points but theres just no room under the car.
  • Like 1
  • 5 weeks later...
Interested in an Intense turbo and am running Itsrom ECU atm. I am getting just over 17psi atm (according to an autobarn gauge) using Scottys dump and front pipe and a Nur tailpipe. The car is vastly improved by Itsrom and has standard intake currently. Was thinking about Scottys Intake or an AMP one and wondered how you got on with yours? People talk about fuel cut and I figure the Intense and an intake is going to get there. You did not mention this so I was wondering what you did ... Thanks
I've had no issues at all with my setup and haven''t had it fuel cut once.
  • 2 months later...
17 hours ago, Skylinefreak1 said:
That's some fancy fab work mate! Looks great! Anything else done recently?
Thanks mate.
I recently bought a TIG welder so I can do aluminium work but mostly to fix up my rear subframe as it's cracked.
I've got a few things in the works including building a new engine soon as the current one is cactus. Just trying to keep this one going until the other engine is ready :654_bomb:
So this is what I have in the works currently and I just tick along with them.
Designed and 3D printed a pistol grip style shifter. Unlike the generic ones you can buy, this one slides on like the factory one and uses the circlip to hold it on snug. The cover at the base fits like a glove but I was limited to how much radius I could put on the shifter to match the cover.
I finalised the design of my 3D printed catch can so just waiting on fittings to come so I can hook it all up and test out how well the ABS holds up to heat and fumes. The fitting by itself replaces the factory PCV and I had to get that from the states.
The catch can is fully baffled inside and just requires some steel wool and the other baffle to be fitted.The top had to be removable as you can't print a baffle inside and object and know if it has printed properly.
If the 3D printed one doesn't work, then I have all the individual pieces cut up ready to be fabbed up. This will be my first TIG welding project since buying one as I have only used MIG.
To get the fumes to the catch can location I made up a steel hard line that goes from the passenger cam cover, along the fuel rail and follows behind the timing cover.
Knocked up a cooling mod but mine uses an SOS fitting as the bleed point. If your're familiar with Caterpillar mining equipment then you'll know why I chose this!
To go along with that I bought a generic breather tank setup that will most likely go above the passenger cam cover. This is the highest point in the engine bay, has the most room and is easier to tap into the bottom rad hose.
After doing the rear rotors I saw that the subframe was cracked on both sides pretty badly, also another reason why I bought the TIG welder. I made up a cardboard template and the aluminium I transfer that to will get welded in for more strength.
And most recently I had a knock senor code throw up after handling the harness. Found this just hanging out in the valley.
Plan is to buy another harness and re plug the whole thing as most of the connectors are breaking apart or already broken.
  • Like 2
21 hours ago, myothercarsa2cv said:
Amazing work Brendon as ever! Some tasty parts there that I’m sure a few of us would be interested in if you wanted to make some more... ;)
I plan on making some of this to sell in the future but I want to run it on my car for a bit to see what works and what doesn't.
I may make up a different catch can setup that uses easier hose routing but it means you can't run the turtle shell.
Edited by Sack87
I got my hose fittings yesterday and fitted the catch can. I'm not 100% sure I like this location now as the lines are just clearing the bonnet as they are sitting on top of the overflow bottle.
PCV delete and hose fitting just have enough room with a 3" intake
I will need to beef up the lid bracket and slightly adjust it as it snapped when moving it around. You can also just see the breather hidden away under the guard. I will move this too as it fouls on the guard liner.
  • Like 2
Really neat and nicely packaged. Shame there’s not a lot of room in our engine bays, would make life a little easier!
Is the PCV delete worthwhile? I’d have thought the breathing would be better with it in place?
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
