Hi guys, not sure if this is the right section. But im in the process of getting a rb26 engine built. Mechanic has suggested going with the  hi octane crank trigger kit. Which is on special for $875 atm. Is regards this setup as far superior to the factory cas. Could I get pro s and con s of the guys running a trigger setup over the factory cas. Ill be running it with Vipec/link ecu. Thanks guys
https://www.sau.com.au/forums/topic/473505-hi-octane-crank-trigger-kit/
The pros are that if they are done right then they are far better than the factory CAS (for hard working engines that is.  For stockers, who gives a rat's?).  The cons are that when they are bad they are very very bad.  Spitting belts and other shenanigans can really take the shine off something that was supposed to make life better.
I have a platinum racing one sitting there waiting to go on the new motor, apparently they can be used with the factory balancer. I hope that is right as i somehow ended up ordering 2 new balancers, would be a shame if i couldnt use 1 of them lol.
The high octane cam sensor has the cover and looks way nicer.
Edited by NEO25T
Spelling
cons = poor designs can cause belt alignment issues for ones mounted to timing gear, have to pull balancer (balancer bolt on a RB26 is a prick of a thing at 446nm), timing belt, timing gear etc to install.
pros = everything else
can use an AEM 24+1 cas disk in the stock optical cas if you want the stock look, and only use the cam reset signal on the inner sensor. platinum sell crank only kits if you want to save a few bucks.
  • Like 1
No issues with it on mine. Only Con is that they provide two of the 45mm red cherry sensors, where there is now a 25mm black version that would go way, way better in their upper cam housing. You can buy them pretty cheap locally too would suggest getting one if you're installing it and care about looks. I do prefer some of the other sensor mountings from other kits for the top, eg ross looks wise but from a practical standpoint its fine, also i've seen others which don't actually cover where the old cas was which is a bit of a worry, leaving belts exposed etc.
Con is you need to run the higher spec ATI balancer won't work wtih the lower spec, stock, or ross as far as I know. You don't loose anything going to said balancer, i have aircon running on it with mine, though you probably need to bring the cutoff down as its overspun vs stock balancer.
Also, regarding platinum kit i've heard that it wont fit some balancers that they claim though i'm unsure on the resolution of that case.
these AEM wheels are junk, same scatter as stock. Ive pulled about 5 out.
  • Like 3
Go see Protek Automotive they designed there own and can fit an tune correctly.
factory CAS are ribbish if your trying to use them on anything but stock ecu or PFC. for some reason the Pfc can just read the factory CAS without issues.
what happens is the factory CAS gets interference at high rpm on other ecu’s and we have seen 10deg in timing jump while running with a scope at high rpm. This is not something your normal tuner or mechanic can see or do, you would be shocked at some big name tunners actually take the customers cars to Dom at Protek Automotive for these kits.
Dom has been doing trigger kits and works directly with haltech and link to put in custom peramitors into the ecu to actually read the trigger kits correctly. Unles your tunner has a scope and has done it before don’t waste your time.
Hope this helps
Hope this helps
very similar to others on the market.
I think you have understood my recommendation about the AEM disc.
You use the single window of the aem wheel in the cas ONLY for the 720 degree cam reset. You'll get exactly the same accuracy of the reset signal as using the cherry sensor on the cam. It's only a reset, and the window on the aem disc is plenty wide enough.
Crank reference sensor is still a must for  a reliable 30degree signal.
Edited by burn4005
I agree, was so disappointed that it came with the big red sensor rather than the small black one...
It also took me about 5 min to get over it...
Does anyone else run an inline resistor like the sensors are designed to have? I don't and get some weird rpm bounce on logs during transition from acceleration to overrun. Doesn't make a difference as there isn't really any need for accuracy there but still a little annoying. I'm going to try and resistor and see if it fixes it
Yes. I run a G4+, previously with the internal pullup. Just the other day I wired in a resistor and turned off the internal pullup.
Car still starts and trigger scope looks good, but that is no different to how it was. Haven't had a chance to drive it and log yet.
ECU pullup is 4.7K, sensor asks for a 1K @5V. My sensor runs 12V so from memory I used a 2.2K or something.
I'd be surprised if that's required. as long as you set the trigger edge to falling it should be a consistant signal.
signal rise time is what they're trying to keep down with the lower ohm pullup. im guessing that the Cherrys have an unusually high capacitance if you need that much.
Yes, those published specs will be for a rise time suitable for the rated freqency of >10khz using cherry's recommended tooth profile.
10krpm on a 12 tooth crank trigger is only 2000hz so nowhere near that. Happy to be shown a scope trace to be proven otherwise.
But if this pull-up change has fixed your issue I'm happy to suck eggs, and is likely do to having excessive capacitance or very high resistance somewhere in your wiring.
But Sure, if this was a 60-2 wheel then by all means 1k is a good idea.
Edited by burn4005
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
