12 minutes ago, mlr said:
Me: "I just dropped my car at the shop"
Wife calls work secretary: "That asshole is modifying his car again, got any work  happening in Siberia?
Work: "Cool, pack your bags, you leave tomorrow"
This is my guess... enjoy your trip this week haha ?
  • Sad 1
2 hours ago, mlr said:
Just dropped off the 86 at Pulse for turbs.
Now all I need to do is be patient, aaarrrrrggggggg.
did you tell them it is pretty important to get it done quick cos plenty of people on the internet are waiting for turbo noises and skids?  that should speed them up
  • Haha 1
2 hours ago, Dose Pipe Sutututu said:
LOL your work sounds fun!
8psi will make annoying noises if you don't run a BOV and metres of FMIC pipe work :)
Might be a job for a coke can blocking plate gasket, Yo
I'm more looking forward to the first time the Mrs hears it, she is going to be well pissed off......her reaction should be pretty funny.
I will just explain that it needed the turbo to quiten down cold start.
That reaction should be pretty sweet as well.
God bless her, and may god have mercy on my soul.
  • Haha 2
When is it ready? I'll take you on with the Tiguan.
It just had both front wheel bearings removed, serviced and re-installed on a 1 year old car with 15k kms lol.
Surprised it didn't throw a CEL and disabled the car :P
Are you still going to tow that trailer up Macquarie Pass, wasn't that one of the rules?
When is it ready?, I'm hoping tomorrow, my boat (real boat/ship, not a R33) leaves on the 13th of this month, this means I will most likely be on a plane on Monday, that gives me the weekend to race a Tiguan towing a trailer up the pass, break the gearbox, and throw a rod, oh, and pack.
It looks like I'm going to have a busy weekend
11 minutes ago, Dose Pipe Sutututu said:
We should all catch up for a cruise in our non-Skylines LOL
I'm spewing I'm going to miss the SAUNSW cruise up Macquarie Pass to Roberstson pie shop.
Although, I do head up there at least once a month for a drive topped with pies, apple turnovers with cream to be then washed down with icecream at Wollongong lighthouse after doing the Jamberoo run.
Mmmmmmm, pies cakes and icecream....
44 minutes ago, Ben C34 said:
Might as well throw the rod out the front of the workshop
1 hour ago, Dose Pipe Sutututu said:
skids
WOW, what a difference
Dyno is saved file from pre-tune in March to 8 psi boost now, WOW
Car is as responsive as farrrrk, pulls hard, WOW
Most importantly is that cold start is not as loud, the turbo has done its main job at muffling the exhaust..........?
Shiny clamps is the only giveaway
Down there somewhere
Pretty black
1567752696411_67962301_10156782546187880_141498161423187968_n.jpg.16b5f8a5d9459183047465f4542be521.jpg
So far the rods are still in one piece
  • Like 3
  • Haha 2
I feel that alot, and I mean all, WRX and STI's cruise around chopping every 86 they see, for fun.
LOL, that has bit them on the arse today, the little 86 is pumping
Not that I went out hunting this morning or anything
I did get punished by a branch falling off a tree infront of me, no time to really do anything but cringe, a few more battle scars but nothing major.
My little 86 is perfect
No more mods needed
Well..........it could do with more .....tutututu
LOLOLOLOLOLOL
  • Like 2
Small turbo kit on a 86 is one of those "enjoy it/great little car" combos. Right up there with a little turbo MX5 at similar power. Sit back, relax, enjoy, and act smug when people who look cool on forums blow up all their money in broken engines.
  • Haha 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
