Demister, there ain't no mist in my car, condensation yes, should be called "the thing that removes condensation from windows when you leave your windows down on a nice sunny day only for it to rain when your in the office half hour later and your seats get wet".
They would need a bigger button though, I suppose it could be abbreviated to "TTTRCFZYWYLTWDOANSDOFITRWYITOHHLAYSGW", that would be much simpler.
  • Like 1
  • Haha 1
1 hour ago, niZmO_Man said:
Mate. Racing > Turbo/Sports
Only if it is part of the main acronym particularly as this is where they use the inverse alphabetic relationship, i.e.:
  • R > -T, S or T (think GTR vs GTS-T, GTS, GTT), however post dash, is direct alphabetic relationship:
  • -T > -R
it's very complicated math, taught out of the reclusive monastery atop mount Fuji.
33 minutes ago, Ryline34 said:
25 GTT
2.5L Grand Touring - Turbo would be correct. Just denotes engine capacity and turbo variant.
25 deciliter Grand Touring - Turbo is more correct.
Why are they all 'Grand'?
I just can't connect the dots to the Vizier, larceny, or Rio.
Maybe its because ...no matter what the problem...its gunna take many multiples of a grand to fix it?  But they use Grand, not 'Many Grand'....so still don't know.
It's actually "Gran" not "Grand" I think perhaps they were initially designed for old ladies since they're so slow.
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
