Haven't got a car to look at just now but I think you need to pull up the plate at the bottom of the door and pull the door rubber back to remove the trim to get at the ecu and there are a total of 2 or 3 I think nuts to remove. Then undo the 10mm bolt in the middle of the plug and pull the plug out and then remove the ecu.
33 minutes ago, kimbod said:
That looks like someone has done that so it can't be removed.
Yup.  Looks like the nuts have been ground down in some weird arsed way.  Your best approach would be brute force and violence.
13 minutes ago, Dose Pipe Sutututu said:
why would you want a PowerFC in a GT-R, get something modern/better
I'm with him.  PFC is a f**king terrible idea in 2018.  Was a terrible idea in 2008!
I did this job in my 34R, yours has been modified incorrectly - As those should be 10mm bolts.
You will need to brute force those pop rivets/shear bolts? as gently as you can to not damage the underlying bracket.
As mentioned, it would be much better to use something newer. I had decent results with Haltech plug in, but there's lots of options. Ideally something that removes the AFMs if possible.
If that's not an option, choose your tuner carefully as PFC+AFM has been known to result in various drivability issues. Ideally only use it for lower power goal.
Good luck.
There’s a few ways to get them out,
you can cut a slit through the middle and use a screw driver,
you can file 2 flats either side of the head and use vice grips to turn them
or you can use a center punch and hammer to turn them
18V angle grinder and just remove the bits that annoy you!
just wanted something cheap to try stop it from running ridiculously rich on 98... currently get maybe 185ks out of a tank
3 hours ago, iruvyouskyrine said:
Car is no good if the ECU can't be taken out, will give you $20k for it as is.
ahaha two hours ago when i was still struggling to get it out i would have accepted that
Good luck.
i live in perth any recommendations for a good tuner? i don't really have a power goal in mind i just want it to run smoothly on 98 and reduce the black soot on my poor white car
Vice grips were the way to go, could slit it wide enough to crack the loctite
Sounds like a problem that could be either:
  • Faulty AFMs
  • Wrong Injectors installed
  • Stock O2s are rooted
