Hi Guys,
I am new here.  This is a great site.  I have an R33 GTR Vspec.  I replaced my cracked stock rad and fan with a Mishomoto rad and fan shroud.  The car did not overheat with the stock rad but did with the Mishimoto.  We tried cutting out the fan shroud so that the aircon fan could blow through the rad but the car would still overheat even at idle on a 25 deg day.  We switched back to a factory fan and overheating is gone.  But now I notice coolant on the top of the rad and it seems to be pushing through the Mishimoto rad cap on hot days. Looking at the setup I can't see how the coolant overflow bottle can work, as the overflow hole is above the point where the cap seals, see below photo.  So it seems like the coolant is heating up, expanding and then has nowhere to go except past the cap seal.  You can see the red coolant on the top of the rad.  I can't remember if the setup is the same on the stock rad.  Can someone with a stock rad check for me?  I also noticed that the coolant was boiling in the hoses today, which was 30+ deg.  Is this normal?  Any advice is appreciated.
https://www.sau.com.au/forums/topic/475766-r33-gtr-mishmoto-radiator/
the spring loaded inner part of the rad cap seals in the lower surface and the top of the cap seals against the top lip that over pressure outlet is in the right spot. You have another problem methinks. Is the spring loaded low section actually firmly touching the lower surface? Is the upper rubber seal seated properly in the cap. Remember the a/c condenser gets mucho hot so a/c fan is blowing more hot air thru the radiator on a hot day at standstill.
Thanks Rusty.
Overflow hose and spout are clear.
Quote
The cap doesn't feel very tight on the 2nd twist so maybe the upper rubber seal is not seated properly - is the cap faulty?  A faulty upper seal would explain the coolant leak around the filler.   What is weird is the cap came with the rad and both are new.  What to do?  Replace the cap?
2 hours ago, georgev said:
Thanks Rusty.
Only one way to find out ...caps are not that expensive
  • Like 1
The mishimoto radiators and fans are absolute junk. You're better off buying a cheap ebay radiator and using the stock fan. We've had multiple cars come in with these setups and idling they see around 107*C temps.
From what I've been told the radiators don't have a divider in them so the coolant doesn't make it through the whole radiator and just circulates straight up instead of going across, up and then back across.
  • Like 1
I agree that the fans are rubbish.  It does not move enough air.  I replaced the Mishimoto cap with a new NISMO item and the leaks have stopped.  But it does feel like the mishimoto rad is running warmer than the stock radiator did.  The a/c used to work the same at idle and cruising.  Now there is a noticeable difference between a/c temp at idle and cruising.
On 1/4/2019 at 8:57 PM, Rusty Nuts said:
Also check the overflow hose and spout are not blocked, mud wasps are bastards.
Does the overflow hose only work one way, from the radiator to the overflow bottle?  Or is it designed to pull coolant from the bottle into the rad when coolant is low?
Works both ways. Designed to let coolant expand and enter the o/flow bottle, then gets sucked back into the rad as the coolant cools down and contracts.
This is all a function of the radiator cap.
  • Like 1
Mishimoto is pretty much overpriced eBay special radiators.
I would find a suitable Tridon radiator cap, I can't say which one you need though.
Also any aftermarket fan shroud or electric fan setup generally never works on Nissans.
Nothing beats the OEM 200 to 600kW fan lol.
So does that mean you can just keep the overflow bottle at max level and the rad will always have enough water?  Or do you guys remove the cap and fill the rad from there?  I'm used to cars with no rad filler just an overflow bottle so I am not sure.
I've learnt the hard way!
Fill from the radiator. The overflow bottle should be above the min mark when cold and below the max mark when hot.
Sent from my A1601 using SAU Community mobile app
Mishimoto has a pretty bad wrap in the Subaru community. It's always hit and miss but a common problem is their caps are garbage as Klutched said. I put a Mishimoto thick mofo in my misses Subaru because it was the only one we could get on short notice that actually fit and used the factory radiator cap and touch wood it hasn't been a problem since October.
1 hour ago, Predator1 said:
Use the stock rad cap. The aftermarket caps are shit esp the ones that come with the radiators.
I would be very careful recommending this.
E.g. if you were to splash out on a nice premium PWR radiator, you'll run into issues using the stock radiator cap. You need to use the CB16110 from Tridon or the Stant equivalent, I assume the same with these run of the mill ling long specials.
Sorry, yes, you’re right. Although my personal experience has proven that a cheap radiator caused issues when using the supplied cap.. issues such as higher temp.. didn’t let it overheat.. easily fixed by sticking stock cap which did fit. Had very similar issues with another friends car.
also, the stock piping may not last with the increased pressure.. .9 bar over 1.3.. another reason to recommend the stock, or equivalent cap.
  • 1 year later...
Ok might as well weigh in here, This has been my experience. I’ve recently done some mods to my 32 R, which included head service + new valve train, timing belt kit, new water pump, thermostat, mishimoto radiator and shroud in which I replaced the mishimoto  fans with Spal Hi flow units. All work was done by a reputable workshop. (I supplied the radiator and fans). When the car was put back together the tuner immediately noticed the car running hotter. (Previously would sit around 82 degrees, was now 88-89 degrees) when you drove the car, the temps would increase to low 90’s but would drop back down when the car was stationary (indicating the fans were working and able to cool).
I was told this was warmer then usual but not excessive, however what we found was when the a/c was turned on, the temps would quickly climb to well over 100, peaked at 105 when the a/c was turned off and the temps started to fall back to low 90’s. This was on a 28 degree day driving street duties, (60-80km/h, low rpm) NO BOOST.
we put a factory radiator and fan back on the car (no shroud) and the car ran perfect, sat on 82 degrees, a/c didn't bother it. Car had to be tuned with the factory radiator and fan.
I got in contact with mishimoto who tried to blame everything else bar their product. Didn’t offer any solutions, I asked if it could be the radiator cap? They tried to blame the Spal fans. The delema isn’t over, even though Mishimoto finally agreed to take back their product , I returned it to the shop for a refund (which they agreed to) but am still waiting (been 2 weeks) been a horrible experience and I am out of pocket a considerable amount of money. Wouldn’t recommend them and I have had just about enough from the parts shop, I know it’s not their fault, they are the distributor, they don’t make the product but I feel they are really stuffing me around and there is no need for it. I won’t shop with them again, that’s for sure.
  • Like 3
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
