f**k it, ill post the daily. For those that know me, and my nismo addiction, KNOW THIS. I have combated it by buying another Nissan with which to buy more Nismo.
The Nismo Cube or for the ladies the Jismo Cube, i know i know, it's extremely sexy.
The list of Nismo parts keeps growing. The latest addition was the MAD Nismo wheels. they are hectic as. Loving the Nismo handle protectors as well.
Image may contain: car and outdoor
  • Like 1
All i'm going to say is CONGRATS! Congrats on getting the other half to sign off on a Cube! If only mine could see the light:laugh:
I think they look cool and...its a freaking Cube- packing one would be like playing a game of Tetris!
Fun to drive around town?
  • Like 1
Fun isn't the word i'd use lol Practical? Maybe...
For a car it's slow and doesn't corner overly well, and this is the rowdy 1.5L version. However my god it is easy to drive. Visibility is fantastic and it has the best cornering circle of any car ive ever been in, it can do a u turn in 1 and a half car spaces. It's also pretty comfortable all things considered.
My other half loves it, she loves how easy it is to drive. She just said it took a while to get over the looks of it.
  • 11 months later...
Well here is mine.
R33 GTST 1997 with sunroof
Gt3582r
48mm turbosmart gate w/ screamer
Custom mani
3.5inch dump and all the way through w/xforce muffler
monsta FMIC
Freedy plenum
Bosch 1000cc injectors
460lph walbro
Turbosmart fuel reg
E85 making 360RWKW @18 psi
Vaastoen wheels
GTR wing
S2 front bar with nismo lip
Oh and fully forged rb25 with all the goodies.
New r35 coils on the way and then we push more boost and more power[emoji16]received_2042995045727821.jpegIMG_20180616_133956_564.jpgIMG_20180629_142836_452.jpgreceived_1872274982824440.jpeg
  • Like 2
  • 4 months later...
  • 9 months later...
  • 3 months later...
  • 1 year later...
  • 4 weeks later...
I'm 5 years late on the cube convo... My 6 year old wants a Cube, I'm like yeah no 🙅🏼‍♀️
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
