Hey guys,
just wondering if anyone could help me out, I own a 1998 R34 NA and looking to upgrade my intake to an Apexi power intake but cant find any for the NA R34, but there is one for the NA R33 and I know that the R33 GTST and R34 GTT intakes are interchangeable, but are the NA versions of these cars compatible?
Thanks
https://www.sau.com.au/forums/topic/479603-r34-na-intake/
My point is, considering it's an NA, there are no performance improvements available from an intake change anyway. So spend your money where it will do some good. Upgrade brakes, or tyres, or suspension bushes, or any of a thousand things that will reap you a noticeable improvement in the car.
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923346
That's what I'm doing, I have an excel spreadsheet of like a million things that I want to get done. I'm more just asking as I cant find anything to do with intakes with my NA skyline, including cold air, I just want advice for my spreadsheet so I can finally have most of the things finished up.
  • Like 1
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923347
Come on Guys.. leave the man do his thing, we were all there once, and dont even try and lie about it. Blitz makes a good one that bolts up to the Mass Air Flow sensor and replaces the big ugly box.
Edited by Dil-Dog
  • Like 1
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923369
What the guys are saying make sense... spending your time and money and things that would make a bigger difference BUT i still recommend it bro, it will improve how the car sounds, you would enjoy it.
Also... there is a forum here called "Naturally Aspirated Performance". you should check that one out. you are currently posted/browsing in the "Rb series" forum which is 99% based on the turbo models.
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923371
11 hours ago, GODZR34 said:
I know its nothing major, but considering I am a P plater, I cant go out and chuck on a racing level Cold Air Intake
Its still a waste of money. Maintain your car so that you can sell it later and put the money into your account for the purchase of the turbo powered car that you really want down the track when you have the full licence.
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923375
19 hours ago, GODZR34 said:
Hey guys,
Thanks
Would be better off modding factory airbox with a hose from front bar/under guard.
1 hour ago, Dose Pipe Sutututu said:
Best bang for buck for a NA is nitrous
^^^^This. On e85 with a 100hp shot
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923381
All that money to make less power? (sucks in hot air from the engine bay)
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923382
Tbh on a NA skyline, wouldn't a pod filter make a decent difference, especially if using a heatshield and cold air ducting?
I've got a NA R33 and gave it a quick run yesterday without the airbox lid and then with filter removed as well and it made quite a big power difference. Was much more responsive and acceleration uphill was waay better.
Put it back together and fitted my GTST snorkel but didnt seem to do anything noticable in comparison to the smaller NA snorkel but would imagine there would be slightly better and cooler airflow. Might be worth trying it after all.
Edited by ossy
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923399
Didn't time it of course but would say it was definitely faster than usual as my NA R33 has always had performance issues where it feels like it goes into limp mode at times but acceleration from low RPM was always sluggish. It bogs down a lot,  as if something is limiting the power but this made it pick up revs and speed so easily... There is the fact that maybe more air helped fix whatever performance issues I have that's effecting my power lol.
Since you mentioned it though, oddly the sound didn't change at all? Shouldn't it make this weird turbo/supercharger like spool sound with the air box removed or throatier atleast? Or is that sound only happen with the intake resonator removed?
Edited by ossy
https://www.sau.com.au/forums/topic/479603-r34-na-intake/#findComment-7923436
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
