Depends how much work and how hands on you are.
"Shell" can mean a lot of different things, from bare (metal with paint) to everything except and engine. Finding things it doesn't come in can end up mega expensive depending on how many things are missing (wiring looms, brake lines, brakes, dash, interior trims, seals, seats, belts etc etc)
I think it's going to be a tough journey
9 hours ago, jmknights93 said:
Start from episode 1 and work your way through the playlist... This should give you an idea of what to expect...
Back when i was at uni i could only dream of owning the cars this guy does. uni must be complety different to what it is in the UK!
nah hes from WA, that wasnt my point though. Im british and went to uni in the UK and couldnt afford a car at all. this lad does full builds whilst at uni here in Australia. Thats what baffles me...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
