Heya folks,
Just got home from a drive and my turbos decided to shit themselves.
I actually had it up on the market but now it looks like that's being put on hold till the issue is fixed. :(
The car is in amazing condition and I don't want to do any big single upgrades or anything like that. Since I'm pulling them out may as well put something a little better in there.
Any recommendations on some decent twins that aren't going to break the bank?
I don't want to have to change the manifold or anything like that so it would have to be something that bolts straight in.
Thanks in advance!
https://www.sau.com.au/forums/topic/483574-twin-turbo-upgrade-r33-gtr/
On 20/04/2022 at 3:11 PM, robbo_rb180 said:
Either rebuild what you have by @hypergear, find a second hand set or 2860-9 upgrade.
Exactly. 2nd is quicker to do and might cost a little more, and you will get 20% more whoosh.
You'd be mad to convert a GTR from twins to single these days unless it is for genuine race only use
https://gcg.com.au/turbo-charger-kit-nissan-rb26-low-mount-iwg-gt2860r-9-xtr000908i.html?ref_cat_id=Turbo-Upgrades-Kits-Petrol-Turbocharger-Kits
This what you boys mean by the -9s?
Also, while we're here - since they're blown and the car is sounding like a hilux, does this mean I shouldn't be turning it on at all and tow, or is it ok to not hit boost and drive it to the workshop?
Edited by Mlads33
I wouldn't allow the engine to turn until you've verified that you haven't gotten a bunch of ceramic bits from the turbine going backwards from exhaust gas reversion. Letting off at high rpm you can see the manifold pressure reach high levels of vacuum.
Edited by joshuaho96
Yes, those. That kit includes the slightly different oil drain fitting you need.
And no, don't run or drive it. Depending what has happened exactly there could be crap all through your oil. Also, it is worth having someone check it out and make sure turbos are the only issue, they don't generally die on their own and there is a chance they can do other damage
Why?
can always put the shit lag wagon twins back on.
A weekend in the garage and it’s “as it was as Nissan intended” or some other dribble that GTR guys love to froth over.
As Brett said, -7’s/-9’s or if you want a bit more poke a set of -5’s. The as it’s been for the last 20 years.
  • Haha 1
It's not 2010 anymore mate, the world has moved on. An R series GTR is no longer for making big power out of, breaking parts that can no longer being replaced, leaving in the garage for years, then repeat.
It is for keeping standard as possible, putting genuine nismo accessories and maybe some period rays wheels on, and shipping to the US when you win GTR lotto.
People don't have to like change but it happens anyway. Ask anyone who wanted to own a GT Falcon or even a Torana in the last 20 years.
  • Like 2
Since the turbos are coming off, might as well pull out the motor for ease and at the same time add in a head drain/sump breather, Nitto oil pump, extended baffled & gated sump, fresh bearings, ARP stuff top to bottom, Nitto OR Tomei head gasket, all fresh seals.
If money permits, a Samsonas too.
Who the f**k pulls the engine out to change turbos? I can have a set of turbos out of a gtr in about 2hrs,
better ring maatouks, crd, jem and etc and let them know what GTRs are for now because they’re building more then ever and finished examples are fetching huge money
  • Like 1
A lot of workshops I talk to don't even do intake plenum/collector with the engine in the car.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
