So I finally bolted this puppy on my recent trip back home:
https://www.alphaomegaracing.com/product/monstar-tailshaft/
I noticed on a long drive through traffic, I started getting some vibration on the motorway around 140+ (after traffic). I'm guessing it expands ever so slightly once heated up closing up clearances.
We swapped back to the oem drive shaft and no vibration.
Anyone else running similar drive shaft? Is there any way to get rid of the vibration? I'm already running whiteline subframe bushes and Nismo rear diff bushes.
Def seemed to be more rev happy and responsive with the 1 piece though!
https://www.sau.com.au/forums/topic/485160-one-piece-drive-shaft/
3 hours ago, Predator1 said:
Any ideas how much power difference it makes?
Highly doubt it, and you're making like 10x the power of your average Toyota 86 or Honda shit box, so light weight or not, you're not really going to notice.
  • Haha 1
Have a Google IRT max tail shaft speed
What is your tail shaft speed?
Calculations are based off tail shaft speed (RPM), length, material type, material thickness and diameter
Balancing should be done at a higher rpm than your average steet car if your turning high rpm
Phasing needs to be correct
And uni angle should be in spec, no uni angle is bad, to much angle is bad, uni joints apparently like a little angle to help their internal bearings spin, some say rule of thumb is between 0.5° and 1.5° for high rpm
This is why jacked up really high 4x4's do uni's
I had issues with my 2 piece when I lowered my K-frame by only 10mm, it basically kept chewing out the couplers because the alignment was out of spec
Like you it developed high speed vibration, started about 90 mph, and was like a earth quake at 124 mph
I got my alignment right, rebuilt/rebalanced the tail shaft, and now it's good to go
2 piece tail shafts have alot of advantages over a 1 piece when you look deep, especially on a street car
Thanks for posting your experience, I was looking at getting one of these. Though, still not sure if the money would be better spent just getting the OEM shaft overhauled.
Thank you, I've literally copied that and will ask my workshop.
I dont know my tailshaft speed, I would assume the speed would match the oem shaft, as it would depend on my gear ratios?
Was that an expensive exercise having it rebuilt? How long did it take?
In terms of max tailshaft RPM. I'm not sure either. I bought it as I saw the Xtreme GTR was running it. I believe he also runs an Albins with the same ratios, and he revs it to 10k IIRC.
I definitely felt the engine to be more free revving with the alpha omega tail shaft. The vibrations were def the shaft, because last week, we swapped it back to my oem shaft, and the vibrations are gone... and I noticed the engine wasnt as rev happy as before(I'm super sensitive).
One thing I just realised was that when I used LC to launch with the OEM shaft, it bogged down very bad. The last launch I did with the 1 piece shaft, it didnt bog at all. I'll upload some videos soon. The launch strategy was IDENTICAL.. I tried to pre-load the drivetrain, then let it out.
I booked it so it was less than a 1 day affair to drop it off, for them to pull it apart, rebuild and balance it, it was only a hour or so later when they rang to say it was ready for pickup
I think it was around $800????, that also included the new, Hardy Spicer uni's, couplers and centre bearing
Did you get the exact same as the Xtreme GTR, as in material, wall thickness and diameter
What was done, if anything, to the Xtreme GTR IRT the uni angles?
Thats a bit pricey haha, but let me see. I'll try to find someone local here if they can check and balance it.
Re Xtreme - I have no idea. I just know they were running one from their website and facebook.
I'll swap the tailshaft out tomorrow and see how it goes.
1 hour ago, GTSBoy said:
I spent >$1K at Spicers getting my 2-piece rebuilt with replaceable unis. It's just the cost of doing Skyline business these days.
Hardy Spicer, Eagle Farm charged me $597 for two piece rebuild as above including pickup and delivery from my workshop ya got ripped.
When you take into consideration the 2 couplers, and the centre bearing, which I priced up the OEM spec Hardey Spicer units at Repco for around $500(ish) for the 3 items, and whatever the uni cost, I didn't think the price was overboard for them to supply, strip, rebuild with new parts, balance and paint
Have you verified your driveshaft uni angle? With my single piece driveshaft on an R32, angle between trans and diff was far from ideal. I had to drop the engine a bit (Slotted out engine mounts) to get proper angle of -2/+2 between the two.
Edited by TurboTapin
  • Like 1
10 hours ago, ChrisW434 said:
I have an AlphaOmega 1piece tailshaft in my 34 GTT, no issues here. Granted, i havent spent much time going 140+ though yet. Still, love it
Good to hear - Have you noticed any vibrations at all when the shaft is hot? i mean after sitting through like 40-50 mins of traffic?
Nope. We had to space the box down by couple of mm too. But issue only seems to happen when the shaft gets hot. I mean its not an issue, but just vibrations. Def can live with, I'm just a picky cnut.
Edited by Predator1
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
