Looking for opinions as I cant make up my mind
R33 GTST 2Dr
Work D9R
FRONT 18x9.5 + 23 OR 18x9.5 +12
REAR : 18x10.5 +23 OR 18x10.5 +15
More so after a "slightly stanced" look & I rather they sit more flush then poke out like a monster truck. all guards are rolled. Liners still in, will remove if need be.
Would love to see your cars if you guys have any photos!
Cheers, Jordzzz...
  • 3 weeks later...
  • 1 month later...
Anyone running 18s enkai rpf1 8.5 +30 front and 9.5 +38 on the rear of a r33 coupe.
Im worried about the brakes clearing
The offsets are what i want just not sure if the rims will clear the calipers. Being wheel specific
All the rpf1 r33s seem to run 9.5 inch wide on the front but i have knuckles and stock length lcas for drift days so would rather the skinnier wheel
Dont want to run spacers if i muck up the sizes
Cheers
Edited by James GT-T
12 hours ago, Adz2332 said:
10.5 +22
How much would the rear have to be pulled to get them under it?
quite a bit... this is 10.5 + 12 but using a s14 subframe so extra 5 = 8 mm wider so maybe a + 15mm wider than you want but still
Edited by bcozican
Skyline model = R33 GTST
Wheel diameter = 18"
Wheel width = 9.5
Wheel offset = 15
Tyre size = 265/35/18R    245/35/18F
Modifications to fit = 30mm wide front guards and shaved 2mm off the rim to raise offset also ran 245s just to make sure.  Rear has 65mm flares and a 25mm wheel spacer.  Wheel specs are for a r32 GTR
Thought I'd share my setup since there doesn't seem to be much info/examples out there for this particular setup. Perfect for spirited driving on back/mountain roads, not so ideal for daily driving or putting around at 3000 rpm, according to suspension guy. No getting around full lock scrub without invasive mods (rear guard rolling and front guard removal). Otherwise everything fits.
Skyline model = BCNR33
Wheel diameter = 18 in
Wheel width = 10.5 in
Wheel offset = +15 mm
Tyre and size = 295/30/R18 AD08Rs
Modifications to fit = Adjusted suspension. Lower and camber, front and rear. As said above, you will need to run slightly more camber than you would in a street car.
IMG_20190706_201716.thumb.jpg.ce92293973bae734d2b3b2b93cd04a59.jpgIMG_20190706_202313.thumb.jpg.2eafbce433310aadbda5ad0b58580b10.jpg
Edited by N155@N
  • Like 3
  • 5 weeks later...
 R33 GTR
19x10.5+12 TE37s w/ 265/30 Potenzas
All gaurds rolled, not lowered too much. Scrubs on liners on full lock but otherwise perfect. Fell in love with the wheels the moment I saw them.
60416403_1060088204201359_3943505182955929600_o.thumb.jpg.4bc2418822f57fe5773376cd47845f2a.jpgIMG_20190330_135826.thumb.jpg.937862cc8b6e924d063ce27adeafab94.jpg
Work Emotion CR2P 18x10.5+5 w/ 265/35 AD08Rs
Scrubbing on full lock, but otherwise great fitment.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
