HKS laid it on a platter and it's too expensive. Why don't you retrofit it to the cams you have now? Make the whole thing yourself from VQ35 parts if you want to save a buck. It's been done already, it can't be too hard to replicate.
Everyone wants to take the easy way, but don't want to pay the price...
Carbon driveshaft won't do much for how the turbos will respond. You notice the throttle response improve a bit.
You want response, 6262 would be your pick, not a 6266.
Agree, but at the end, either is engine response or turbo response, your but/head will still feel its a bit more responsive than it was :)
To be honest, I'm looking at different turbos option but to quote my supra friend '' damnnn can't believe the cost of a single conversion on your RB is 3x more expensive than on my 2jz'' So, as much as new gen2 billet wheels from Precision or EFR can be good option and yeild better result... for 6-7k, I might as well built a RB28 and keep my -5 ( or have a hta2869 wheel upgrade) and make good power too :P
Edited by cobrAA
  • 3 weeks later...
Where do you live? Just remember that they made the 26 to be a 26. Stick with the 26 and don't worry about stroker kits or 26/30 combos. If you go to a tuner that knows what they are doing you'll make over 1000hp with the 26. I'm sure that is more than enough for what you are chasing for the street.
I bet the response on a 1000hp street car will be fantastic
As in it will be fantastic when it finally responds ;)
That's some strange advice.....
Having said that, check out the clip I posted in the Borg Warner EFR thread - 900hp @ crank RB30 drift car, pretty fun stuff :) RB26 with 1000hp however, not too exciting but not necessarily as bad as some may think these days.
  • 3 weeks later...
I recently changed my T78 for a PT6262(help from SAU) and installed Poncams B because it was not a car you want to have for a DD. It was laggy as hell and with the quad OS clutch was a pig in traffic, especially on hills.( did miss that neck snap when the T78 kicked in at around 5.5Ks up into 9Ks) I can only imagine what a 1000HP machine would feel like, whooow :)
Here are the Dynos , brown PT6262 new tune, it is a different car to drive. The quad clutch is no longer a problem with the extra torque down low, just love it :)
Going to have a custom exhaust system installed as it is bit restrictive, Walbro 460LPH fuel pump and a Haltech Pro R34GTR ECU , the ECU is because my Apexi FC is playing up and nothing to do with trying to get low end power.
After this has been completed and on the Dyno I will post the new chart, hope it is what I am after, a gutsy street car.
Totally different car, early response, smooth power on bends and keeps going. It was good to find out how good they can be and if I want, I can make it even better, well the $ can :)
I never had much of a chance to drive it after the work was done, 3 hours into the trip home the Apexi ECU lost the new Tune, about 45 Klms from home on a bush road, cars eh, haha
Will be interesting to see how much more responsive the new exhaust system makes it, any extra will be great.
With the fuel supply upgraded it can be tuned up as the motor has been worked and the extras added to support the power it is capable of. But I am not after top end power, just early and whatever else comes with the new work.
I think you'll be pleasantly surprised how much better the car will be again once you fit up the new exhaust and fix the fuel system.
Should be able to grab another 70 -100kw out of it too if your keen to wind the boost up :)
  • 1 month later...
What is it with these cars, once you start playing with them it is hard to stop until you get close to what you wanted.
I want more Torque, still do and looking into getting a Nitto 3.2lt Stroker kit,from what I have read I have many of the mods needed to support any extra KW/HP and it will give me the Torque that I am after.
If I do this, did I waste the money I just spent changing to the PT6262 and the Poncams B.
I am still doing my homework, been looking on SAU and got nothing so far but I am sure it is here somewhere??
Well if you're going to all the effort of fitting a stroker, you'll be sorting the head out too. Really, you won't be dicking around with "drop in's". Relieve the head and get some lift up it.
I disagree.
A PT6262 on a 3.2 will drive like a monster in low end, and still produce a good final power figure easily.
Set up a 3.2 with a 9:1 compression ratio. Port you head and keep your B Poncams. You'll be surprised just how good it will perform on low end. If the budget permits the get some more lift like Paul suggests.
The larger you go in displacement, the angrier the cam you can get away with in a street car.
Edited by GTRNUR
I disagree.
This is basically what Jim said because I am after low end response and utilize all of my recent mods and use the existing head, I will ask if he intends to port the head.
He is working towards what I want, response for a tough DD and keep the costs down where he can without jeopardizing the build . One that can be changed if I ever wanted to go for power up top.
I know there are many ways to go with this and I could get some serious HP but I do not really want it up top so I will go with what he has recommended for my requirements.
I will ask about getting some more lift and see what he has to say. We have only spoke about this today and there probably be other suggestions to look at as we tie up the loose ends and get a better idea of the cost involved, that is the scary part,haha
Thank you all for your input
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
