My money is on gtsboy
This. I half wanted to weigh in here too, but I'm sticking to my "Try not to care too much about forum conversations" pledge and he has a habit of saying things I am thinking anyway so I get the enjoyment of it without the frustration of writing lots of stuff and finding a lot of it falls on deaf ears, or gets recycled and then regurgitated back to you as though you are being taught something so this works much better for me :)
The whole way this started was comparing like setups anyway, its going kind of off topic anyway - we end up down a path of levels of extrapolation in the comparison getting bigger and bigger and it reaches a point where we may as well say "BLARH my Dad is bigger than yours". If no one else does I'll try and collect some useful data on the SS2 when I get into tuning it.... I kind of wish I still had GT3076R log data on hand, but either way its clear than the boost threshold difference is probably trivial which makes the SS2 a good thing, again because of how convenient it is price and bolt-on wise.
  • Like 1
Yo Lithium, logs attached!
Looks like I get:
1.1bar at ~3600rpm
1.5bar at ~4300rpm
However like I said earlier, my gain is set pretty low
Also here's a virtual dyno print out, not sure how accurate this is either lol
9-18-2014_2011.xlsx
  • Like 1
Awesome, good data sir! Will check out the xlsx when I get to a computer but that gives a good idea. Very very similar to a GT3076R, solid looking power too :) I know VD had issues with MAP in he past, I assume it still does but still... seeing 3.6 bar on the pressure plot for a stock 25 makes my eyes water haha.
Just confirming, is externally gated?
Cheers for sharing :)
Of course you can!
Just download it, choose the right car/tyre settings and upload your logs.
You'll need to trim the logs though so it's only one WOT run in 3rd or 4th. I tried to upload an entire log and it turned out like a mess lol
I think the 2 conflicting examples of spool of E85 vs petrol goes to the heart of the matter. I am no expert but I thought I'd put my musing in here.
I'm assuming it does indeed come down to heat in the exhaust flow which comes down to comparative AFR during spooling. If tune E85 and petrol to the same lambda during spool then the extra E85 mass at a given lambda will reduce heat in the exhaust compared to the petrol tune and reduce spool. If you tune E85 to a bit leaner during spool then this effect will be minimised and perhaps even allow E85 to bring on boost sooner due to the greater power & heat generated. Since E85 gives a wide sweetspot for MBT then it does allow it to be a bit leaner during ramping up without affecting timing.
^^ This is probably very true.
If you take the freedoms given to you by E85 and run with them, you will almost certainly be able to overcome the cooler exhaust effect.
The reason I said I wasn't going to do the math is that I was sitting in San Fransisco Airport United Lounge between a 6 hour trans con flight and a 15 hour trans Pacific flight. Simply wasn't interested in anything that even seemed remotely like the work I had been doing for the previous 3 weeks. Now that I'm home, and not going to the office this weekend or Monday, I'm still not interested.
Maybe later.
I'm thinking better torque timing in the spool phase but injector performance would play a part here . A big old world injector won't react or probably atomize as well as a modern one so being rich here is probably safer overall .
Ill tell you this
My tune with the ss2
98 = ~355whp @ ~18-22 psi
85 = ~345whp @ 16 psi
The 85 tune has alot more midrange, comes on power alot harder.
Its also faster...proven at racewars.
Ill tell you this
Do you have the torque graphs? I would be interested to see your torque gains running similar power output, on the same turbo.
Updates on the GTR. 130KMs drive to see Brandon at Brae fabrications. It is now now high mount installed, running one of our 50mm external gate.
Don't know if this is a N1 GTR. Factory turbochargers removed are busing bearing N1s with steel turbine wheels. That explained all the extra power.
Turbocharger used for this evaluation is our latest billet SL20.5
I've heard few people mentioning that the Rb26dett engines are laggier at spooling up the same turbocharger as if it is installed on a Rb25det due to the lack of VCT unit. It didn't feels like the case. Be interested to see what the dyno says and comparison against standard Rb25dets using the same turbocharger on similar setups.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
