From what I read of Stao's plans the idea isn't to build the fastest car in the world, but rather build a turbo to suit the common bolt on mods that most people do.
Lets face it, when most people chuck their first exhaust system on, they're aren't expecting to one day make 400kw, but we all know that the power bug does bite. Most people won't then want to swap their exhaust and intercooler and whatever else, they will just want to max what they have. And I think that's the idea of using the JJR 3' and the return flow cooler
  • Like 1
Thats right staos plan is to use the "common boltons" that people use and see what sort of figures these mods can potentially make if pushed as hard as they can go. Which i think is a great idea. But i stick to what piggas said.. but then money comes into the picture so yeah its a two side story
3 inch for 400? Errr...
Golf ball and garden hose.
I read what was said as being the JJR dump was a bad item to use in general.
I thought zebra was saying the JJR is not "Good".
Of course going bigger is better, getting a mild steel system made up is by far the cheapest if you are on a budget.
What i was saying is the JJR dump is perfectly fine piece, the only issue people seem to have is sometimes they don't line up to the 6 bolt stock flange.
But if you want you can look at the dyno thread and see some people with 3 inch exhausts up in the >370kw range.
Stao himself has results with 3 inch exhaust in upwards of >370kw
Even one of his later ones is upwards of 430kw with 3 inch..
Edited by jay-rod
Mine fit perfectly fine, but that's just one person i guess.
Since then the flange has been chopped off, so fitment/gasket issues are nill.
And if the average person has the choice between a 199 dollar stainless dump and a 400+ brand name 3inch.
You know what most people would choose.
But i do agree, 4 inch would be better way to go, but not exactly necessary.
Its not really possible to get off the shelf 4 inch or even 3.5 inch for a reasonable price unless you get it made up for you.
Especially the r34.
I think stao's main market is the bolt on people here, and those people are not really in it for the "max dyno" number.
The best exhaust is no exhaust. Some of the cheap and loud exhausts actually makes the highest power. Due to the size of turbo compressor, the whole turbo has to be spaced 15mms towards chassis side. 3.5inches would be making it hit the chassis rail. well I see how it goes first.
or run an external with a screamer pipe, ain't nobody got time for a big exhaust :)
My car is now more quiet than a stock SS, until I crack ze gate
Lol, not everyone has 4k for an exhaust.
Tao is trying to make 400kw with the smallest of budgets, which I am all for. I agree a 4 inch may give you another 30kw, but bang for buck that's a riporf.
  • Like 2
Not sure whether to start a new thread or continue in this monster anyway..
Looking at a high flow for an r34gtt. Spoke to toshi and he reckons for the street go the r33 rear housing but for the track the r34 housing.
I am keen on response so thinking of going an r33 housing and the basic high flow. Is that the best one for response and factory look?
Anyone with comparison to the stock turbo? I had a gcg on an r33 and that was really good. I see these HG turbos have more development so hoping they are atleast as responsive as the gcg.
Anyone got a basic HG r33 high flow on an r34 and able to provide the following
At what rpm do you get 18psi in :
2nd gear
3rd gear
4th gear
What power are you getting?
The stock r34 turbo is pretty responsive. I'm able to hit about 8psi by about 2300 in 4th I think. Would the highflow with the smaller housing be about the same (I.e would have bigger wheels but smaller housing so spool up rpm would be similar?)
Toshi reckons the high flow would be full boost by about 4k rpm but on the r33 with the gcg I had full boost by about 3.5rpm so still deciding if I should go gcg or HG.
Many thanks
Try the search function mate, here's a couple I was able to dig up pretty quick
Further updates:
John Reco's R33 skyline. standard engine with cooler, exhaust, fuel and ecu mods. 310rwkws @ 20psi E85 fuel.
I also got a print of John reco's R33, thats the first time I had a proper look at his result. It is running our standard 21U high flow on E85 fuel, and I'm amazed of how responsive it is.
Result sent in by another member that is currently using our 21U high flow running E85 fuel making a super responsive 311rwkws on 20psi internally gated. That is on a R33 Rb25det stock engine.
As you can see they make a little over 300rwkw on E85 and the are pretty responsive
Current state my ss2 makes 18psi at 4100
but its under the knife atm and should make 20 by 4000 on flex fuel and external gate... my mates r34 gtt has the u21 (r33 highflow from hypergear) makes full boost at 3700ish on e85 19psi
any of the highflows will be brilliant and the ss is a whole another level of aggressive boosting
if you want response the u21(33 highflow) is your best bet, its not as responsive as stock but its as good as itl get. The op6 (34 highflow) is a tad laggyer (300ish rpm give or take depending on suporting) but has a higher power output. but If you look at going for the op6 i would highly recommend concidering spending a bit more and go for an ss2 Its an unreal street turbo and bolts straight onto the r34 turbo mani and lines up with stock dumps
My 2 cents cheers!
I've had both the OP6 and 21U turbine housings on my R33, look up my results in this thread and make a decision.
If you're used to full boost by 3.5k, going for the 21U version is a no-brainer, especially for a street car. 500rpm difference in response doesn't sound like much, but it's a big difference.
The 21U should be well and truly on full boost by 3,500rpm, mine hits it by 3,400 and is running PULP.
Edited by colourclassic
Hi, I've been MIA for few weeks due to an small operation and now back on business. I'm catching up with every one's jobs, they will be all out this week, I apologise for the delay
The R34 test rig is in progress and will be tuned with the latest SS2 prototype this friday, hopping for 300rwkws+ with 20psi by 3500RPM.
Dyno reading from a high flowed OP6 turbocharger, making 275rwkws internally gated @17psi, pump fuel:
And posting a small video from twin ATR43SS2.5 powered LS1 V8 maxing out the dyno at 12psi, its apparently making over 1000Mn of torque. Their dyno is getting upgraded, hopefully seeing over 1000HP+ on a full run.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
