Some good figures out or a R33 AUTO, P98 fuel using our 21U STD high flow making 262rwkws @17psi. Usual bolton mods, Tuned By Boosted brothers in SA.
If it got 262kW out of a 21U at 17psi, what do you think a SS2 at 18psi with usual bolt ons would achieve ?
My ss2 on an unopened 186k/km neo made 265kw at 18 psi with boost leaks and top end restrictions using basic boltons
That result isnt a 21u housing...
its a Auto C34 Rb25 Neo RWD.
Its a 0p6 housing.
But it still is a GREAT result...as the car has a stock plastic turbo intake pipe haha .... , a stock op6 turbo actuator.. and a just jap return flow cooler....and a bleed tap..
if it was manual.. it would be 280rwkw on 17psi..
cheers
darren
Ok, cool. Here's some thing quite extraordinary. I found my previous run using the ATR45SAT int gated prototype had a collapsed rear muffler.
Had that replaced and, it went up to 380rwkws then run out of fuel. My Walbro fuel pump played up shortly after as it started to run lean and leaner after each dyno run.
Without the extra back pressure boost creeped to 23psi up top, its not perfect at this stage. More development will be conducted. But 380rwkws out of internally gated bolt on turbo is a pretty good result. With the extra fuel I'm pretty certain it will reach very close to 400rwkws.
  • Like 1
This is getting beyond ridiculous. 380kw out of a literally 'bolt on' turbo with very minimal supporting mods. I can't believe some of the stuff you are putting out recently stao, incredible work mate.
  • Like 2
What's up with the Walbro mate? Should be good for 450ish. Better check the hose intank, was the relief valve between the pump and lid removed? I bet if you replace the dodgy fuel filter the 34's run you will find extra flow, did Trent try bypassing the filter on the dyno?
I removed the fuel filter and replaced it with a straight piece of metal pipe, made no difference. It started to run lean, and leaner. The voltage to it was fine, the pump has now been replaced, I'm hopping to see this issue solved on my next dyno run. similar scenario happened to my R33 two years ago, except that pump just stopped, left me on roadside for a few hours.
Don't get another
That's great advice, I have sold hundreds without issue. Best intank on the market, but most cheap out on the wiring. These need a 70amp relay and decent wiring like anything that draws 25+ amps.
The chances the pump is at fault are pretty slim. Most likely your relay is flogged Tao, try a direct power feed.
Stao, is that the same turbo I have? The ATR45SAT?
Oh, and is that on pump or E85?
Hi, I'm not sure. This is probably the only internally gated prototype ever built. Yours could be an externally gated model or a SS2 internally gated, best refer to order list. It managed 353rwkws on pump before running out fuel. But at 23psi of boost the car was pretty happy with timing and happier to take on more boost. With every thing working it should be maxing out towards 400rwkws E85 or about 370rwkws on pump.
On top of that the turbo it still makes 20psi by 3800RPM and over 200rwkws on either P98 or E85 @ 4000RPM, it makes a pretty good daily.
Just checked, it's the ATR43 G4.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
