Yes, In my opinion it is still laggy. But that is greatly outweighed by the power it produces and the smile it puts on my face on boost. Mind you it has performed just as well if not better than Stao has described it would so the turbo for what it is is great.
Mods are as follows
Z32
3" exhaust, no cat, 1 muffler (home-made)
600x400 bar and plate cooler with return flow piping, assuming its home-brand as i only paid $50.
Tial 44mm gate (17.64PSI)
SS2 0.82 type b
52mm Radiator
bcpr7es copper plugs
DW 740cc Injectors accompanied by a Bosch 044 (intank)
EVERYTHING else is standard
Laggy?lol Thats not laggy full boost at 3800 is great. You need to drive with a 3540 hitting full boost at like 5 k thats laggy.
As we have said before, laggy is subjective. and that full boost is at 3800 in 4th gear, i mostly use all the power in 2nd and 3rd, and these gears naturally require less load, so the boost is going to be later than 3800 in 2nd and 3rd. I have no idea why people are so surprised i think its laggy. Besides that im happy
Edited by adam999111
As we have said laggy is subjective, and that 3800 is in 4th gear and 2nd and 3rd i mostly use the power in, and with a gear with less load the boost is going to be later than that anyway. I have no idea why people are so surprised i think its laggy. Besides that im happy
My mate has the same setup as you external on exhaust housing, stock manifold , but garrett .63 3076 56T ,fullboost 18psi by 3800 aswell
when it made 295 rwkw, what was the power at 4000rpm?
Edited by jet_r31
@Stao
Do you think you could ever supply a turbo with the gate pre-welded on the rear housing with a 4x bolt dump? If you need a guinea pig, my hand is up :woot:
The reason why I want this is because it makes manifold choices easy, not to mention the ability to make the engine bay "appear" stockish.
@Stao
I remember quite a while ago he did offer one with the gate welded onto the housing.
If you can send me a turbine housing with a 4 bolt dump pattern I should be able to modify my rear housings with that pattern. Its still recommended to have external gate welded on stock manifold, That will delivery better result.
Its pretty good result from the SS2 based on the boost level, need a stronger ext gate spring. should reach 300rwkws. Personally I believe its pretty decent for the power. The current rear housing makes about 200rpms better in response, drop in an email for free trail.
Whoever purchased a ss2 running ext gate is in for a treat.
Just got my car tuned at chequered tuning
Initially got 295 but wanted to be safe so turned back the timing.
So final =
276rwkw
18psi tapering to 16psi
Full boost at 3800
There is an abundance of wheel spin and really quick acceleration . Very happy.
Its got about almost same result as the one on mine. But I had the smaller rear housing. Be interested to see results using Stao's new housing over lied with ours.
My ss2 arrived today, going in for tune + support mods on Monday
I believe you've got the latest SS2. did you end up getting yours tuned?
Edited by kwickr33
Just did a winton drift practice day and may i say, the turbo ran really well, not one problem and is the perfect amount of power for third gears slides, car did not loose one bit of power thrashing it all day and was very consistent. Had to learn to keep the revs up but once they were up, i was like furk me this is good.
Sorry mate, No longer have the SS2. Ended up going a different route with my turbo upgrade and Stao was a pleasure to deal with in the procees.
I've got the latest. Hoping to fire up the engine today and if all goes well ill book it in for a tune tomorrow
Stao can you PM me the SR20 SS1PU result? that is the results I am looking for.
Here it is. SS1PU internally gated bolton version for S13 SR20det non vct.
The thin red line is on stock cams, while the thick red line is on big Tomei Pro 270 dur cams which made it bit laggy. The tune is based on pump 98.
The car's not 100% done at this stage, my expectation sits around the 280rwkws with bit more boost once all finished.
This is my last run on the new SS2 on 98 just before the head gasket popped (engine was playing weird on couple of runs before we noticed it, so discard the dip before 2800rpms). Result is overlayed with Adam's SS2.
The red line represent result from the current SS2, while the rest are from Adam's car. There is slight increase in boost response.
Is that internal or external gate?
If internal I might have to get a ss2 instead of a ss1PU!
And if its internal PM me a price if you want to sell your ss2, and reply to my PM whilst your at it :D
That is dame good for pump 98 result. looks more responsive then my ss1pu. what sort of boost were you running stao?
I believe stao was running around 20-22psi hence the power difference. And I was running. 18 down to 16psi. Mind you Im running straight off The waste gate with no boost controller at all. Stao was right External gate makes a huge difference in power figures. I think my car could make 300-320 on 18 psi (at 6000rpm) considering. It made around 290 on 16psi (6000rpm)
Is it just the scale being used on plots or does the torque fall over a little at the top end?
No not the scale, that's the main downfall with the hypergear turbos, good spool and power but torque nosedives after 6500rpm
Edited by SimonR32
thanks for posting this, what is the price in external gate T3? .63 AR
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
