That one is a bitch to change
Good luck
Thanks prob get some mates over so I don't have to do it all alone and to talk shit
Sorry to hear mate, Buy some gaskets and change anything suspect while your on the job :)
This will be the go if I'm changing that may as well fix the lot
G2.5 is a smaller turbo then a G3, they generally maxing out towards 260rwkws mark. So its about at its limit.
He's right, the graph shown is for a G3, but the intake leak might still be present and causing the 5ish psi boost drop. Fixing it might get him another 10-15kw from threshold to redline, definitely worth investigating.
http://www.hypergearturbos.com/atr43.html
The link says G3 but that is the graph from the G2.5 on the page. Either way I will suss out any leaks and give it another run soon.
That G2.5, I thought was a high flow. Preload the actuator about 10mms, if it starts to pin then its usually a restriction some where. This one don't have much of boost drop.
also stao,
your new website isn't meta tag searchable/ google submitted as i cant seem to find the new one on google which is meant to have more details on your range then the old website
Hiflow of a stock 25 turbo? It has a 3 inch inlet so i don't think so
lol... does it fry tyres when you smash the pedal?
Yes it does, because the car is so big and front wheel drive, it wheel spins on the spot with stock tires. lol
Preload the actuator to about 10mms. If you a have a boost gauge, check the pressure drop before and after the cooler, also try a run with no exhaust on.
Time for some M/T tyres? :P lol
This is for a good comparison of the new ATR28SS1 V ATR28G1 based on the Kia's G4GC engine:
SS1 at 8psi, G1 at 12psi:
ower:
Thin red: SS1 @ 8psi,
Green: G1 @ 12psi
Thick Red: NA none turbo @ 0psi
Boost:
Green is G1,
Yellow is SS1
SS1 at 14psi, G1 at 12psi:
ellow: SS1 @ 14psi
Green: G1 @ 12psi
Red: NA @ 0psi
Boost:
Yellow: SS1
Green: G1
This is an excellent turbo for around the 200rwkws on a SR20det.
I don't think that would be a problem. I can upgrade it to the latest profile, which is targeted at boost dropping issue with internal gate. PM if interested to go ahead.
Those are a set of CT20 Toyota Supra turbochargers that I've recently done. Those are rated to about 400HP each. Running ATR28G3 CHRAs. photos shown compressor and turbine wheel comparison, profiled compressor and turbine housings, and completed turbocharger assembly.
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
