Rb25det owners are the back bone of this community as well as my workshop. I've purchased a better conditioned R34, it is fully stock, and I will be modifying it all over again. It is a good opportunity for members whom might have missed my previous build and hate to dig out pages.
I will sum up lists of parts I'm ordering and label prices and shop names.
For members inquiries about the Rb26dett, Using unopened engine, I don't think its possible to get much better response using the simultaneous twin system. For a single high mount, I can get you pretty close to the -9's response while getting -5's power.
For RB30det engines, It varies, I'm getting all sort of engine CPRs depending on whom its built by. Generally using a Rb25det head and a NA VL 3L Bottom you end up some thing like 8.3:1. You can use our ATR45, ATR45SAT or ATR45SS on those to get very good response and decent power output. I'm keen on Rb30det results also, PM if you need a turbo for it, I'll be more then happy to trade discount for results.
  • Like 3
As for shopping basket, list below contain prices and names of where they came from.
Car is fully standard. Goal is 400rwkws E85 using a single bolton internally gated turbocharger, Prices are quoted in RRP by perspective suppliers.
1. Xtreme Pull type Cushion button heavy duty clutch KNI25003-1C. from Race brakes : $891
2. Splitfire coil packs from Just Jap: $589
3. JJR's stainless steel R34 3inches turbo back exhaust system: $770
4. XSpurt 1000cc top feed injectors from Injectorsonline.com: $750
5: Walbro 470 L/H fuel pump from Injectorsonline.com: $200
6: Adaptronic R34 Plug in ecu: $1499
7: Havoc Fabrication Front mount cooler kit: $850
8: 4 inches metal induction pipe made by few silicon hoses and a pod: $100
9: Complete dyno tuning from Chequered Tuning $750
10: I will be using my own ATR43G4SAT internally gated bolt on Turbocharger. $1250.
Total spending: $7649 Plus about $500 in labor it works out to be $8150.
This will be a ball park figure and parts that you will be looking at when comes to performance mods. I will be updating as project progress.
4. XSpurt 1000cc top feed injectors from Scott Fisher: $750
5: Walbro 470 L/H fuel pump from Scott Fisher: $200
A 3 inch JJR exhaust is perfectly fine.
A bit of die grinding on the dump flange and its perfect.( if using standard 6 bolt )
3 inch for 400? Errr...
Golf ball and garden hose.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
