The R34 test rig is in progress and will be tuned with the latest SS2 prototype this friday, hopping for 300rwkws+ with 20psi by 3500RPM.
Just saw that and my pants tightned slightly lol
  • Like 1
Hey Tao I saw the ATR45SAT results on the standard rb26. 400kw 24psi e85. Boost comes on barely behind the standard twins! Did you have adjustable cam gears at all?
I look forward to fitting that
turbo to the 2630. I'm picking up the short block in the next few weeks so I should organise the turbo + 50mm gate asap
With the new SS2, the original print is based on the 21U high flow, except I have the freedom of using larger internal gate and different types of wheels, it is very promising.
The Rb26 ATR45SAT result, is from a unopened Rb26 engine using factory cams and cam gears. It drives extremely well on road, picks up boost nice and early in low gears and respond extremely well to throttle just like stock turbos. This turbo is designed for standard RB26 engines. By adjusting cams gears, responds should be improved that could possibly match the standard T25s.
Edited by hyper-gear
  • Like 1
Right, I've got fuel pump, clutch and injectors, all I need now is the turbo.
I was originally going for 300ish rwkw so was looking at the SS2, however the car is not a daily so why not shoot for something higher? That would be the G3 I believe?
Is there a guide on what's required to fit the G3, Stao? I will be taking it to one of the local guys for fitting so want to make sure they have everything required to get it on.
Also, what's the best way to go about making said purchase?
If its for a Neo motor, I will recommend our ATR43G4SAT model. That turbo wold be good enough to hit close to 350rwkws pump internally gated. Cost same as the G3, you can find it on our site under the ATR43 page. cheers
Hey cowboy, if its not your daily. Might i reccomend instead of doing that. Why not just go for say the 21u or the op6 On full e85? Both have seen over 300 fair easy on e95 with basic bolt ons? Just a thought :)
I've put a lot of thought into E85, and really want to go down that path, but I think that'll have to come with a flex tune one day. For now I'm going to stay pump. I sized my injectors to give me the capacity to go E85 one day.
It is for a Neo.
Is it basically bolt on?
Yes, Check my last result from a month ago. made 311rwkws on 20psi with a cooler restriction with pump fuel. It can be made as a bolton turbo. Cost $1250 inc oil line.
Is this what I need to order?
OMFG, finally, it is done.
After talking about it for what seems like years I've finally put down some cash.
ATR43G4 Ordered!
Now just need to get it all fitted.
I have the following:
Walbro 460
Id1000s
Split fires
Car already has fitted:
Exhaust
Front mount
PFC
CAI
EBC2
Iridiums - will gap down to 0.8mm
Anyone see anything I've missed?
I'm shooting for 320+ on pump.
ATR43G4 Ordered!
Walbro 460
Id1000s
Split fires
Exhaust
Front mount
PFC
CAI
EBC2
ditch the iridiums and get bcpr7es plugs.
  • Like 1
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
