My problem was the I got ebay chinese 1zz coils (were not stamped Denso), and they just fail and don't give spark.  I replaced them with vdo branded 1zz coils and they are fine.  You will be fine with either VDO or Denso.
I am off to Lake Mountain Sprint this weekend in the Skyline
Hi Ben,
Thanks for the quick response.
Good luck at Lake Mountain, with all the rain we've had over the last week I imagine there will be a fair bit of debris on the course. Have you done an event with Mountain Motorsport before?
I'm back from Lake Mountain.  I had the car come off the trailer on the way to the boat which damaged the intercooler, no holes but blocked a few tubes.  Thanks to Roy for looking found Melb for a replacement, but I recided to use what I had.
It took me a while to get back up to speed, but by the last few stages we were starting to get the correct amount of speed from the car.  Still some more to go, but getting better in the lead up to Targa.
This was the last stage for the event.
Fire was pretty small.  I overfilled the sump, so it spat a heap of oil out, when the catch can filled up it started putting oil in the engine bay, which found it's way onto the turbo.  Made it out for race 1, but it was cut short because of an evo that couldn't handle the wet.  Hoping for more rain tomorrow
Fk, given the carnage down there this weekend that is a big call.  Looked to be a bit of a shambles with just about every race having bent cars in it.
Loving the variety in your category.  20B Rx, four Skylines (Who's is the Calsonic one?) and two nutters running Westfields in a category that includes Falcons and Commodores. The Emo ok or is it stuffed as well?
Post up your interview. Looked smooth.
Race 2 was great today, torrential rain.  I went from 10th to 4th in the first lap before being red flagged.  On the restart I went from 10th to 3rd on the first lap, and ended up 4th at the end of the race.  I had oil pressure problems (not enough oil in sump)  in the last race, so pulled the car in before I damaged anything.
The calsonic car is a local one.  gtst with gtr wide body and rb26.  Emo isn't too bad
I just need to find the correct oil level for the new sump for the circuit.
  • Like 2
  • 3 months later...
So I did a hill climb a few weeks ago and the car was pushing oil again, so I decided to investigate it properly.  I only got the problem after I put the new sump on, so I looked through some old logs and compared it to current logs.  It turns out by fixing the oil pressure (or lack of pressure) problem I had created another with too much oil in the head.  A few years ago I get followed the sydneykid guide for the oil restrictors (1.25mm and block), but that starved the head and made the lifers rattle.  So now I'm going to have to go back to that setup.
So since the head has to come off I've decided to strip it down and do rings and bearings, and also fix the bits that weren't done properly when it was rushed together the first time.  So it's off at the machine shop at the moment to have it ready to go for snowy riger sprint in Sept
Sounds like we get advice from the same people.  my restrictors are threaded so I'll be able to but new ones in, I was going to run mig tips but they were too hard to get a die over.  I'm planning on 2x 0.9 (from 2x 1.5)
The Skyline dash is suede from spotlight, at the time it was cheaper than flocking.
I did get a flock kit from a woodwork shop to do the dash of the Subaru, it's pretty easy, paint the glue on then tip the flock on then wait.
  • 4 weeks later...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
