Hehe nice. I wanted to hug it when I first saw it, then maybe see if I could eat it.
Sadly though - not sure if I am going to ever get a chance to fire it up - looking at another option that could have me abandon the entire build... :ermm:
Is that an RB30 block in the background of Chris's engine room?! Whats he doing! lol
Why would you stop so far into this build? It seems everything has been done properly from the outset, the end result wouldve been just awesome.
Believe me I know how nuts it sounds and it kills me to be doing it.
Problem is I am still a good $25k+ short of rolling up to a start line. If I cut my losses now while most of the parts are still brand new and in their boxes, motor is new etc, it is going to end up costing me the same or less to get into an already fully developed car, built to the rule book, with proven pace, that is also pretty fresh.
Most of the parts will be sold off.
Trying to work out the best thing to do with the shell. Will probably still put it in paint and get it for the most part back together so it's an attractive option for someone wanting to build a caged car. If I can convince the missus that nobody wants it for long enough to get enough cash back together I might end up keeping it. Still very attached and would love to see it back together in my garage.
Anyway - no signed sealed deal done as yet but its in the works.
that black wrinkle paint job on the motor came up mint
did you spray it? if not where did you get it done?
great build thread
The guys from Racepace did it for me. It's just the VHT wrinkle black you get from Repco, Supercheap etc. Looks awesome.
You need to make sure you do it in warm weather and put enough of the stuff on otherwise it can come up a bit weird. Even better if you can get it in a low bake oven - my spray painter showed me a strut brace he did in his oven and it came up really sharp.
  • 1 month later...
Some more progress. Mick was almost finished cleaning up the underneath when I dropped in.
The rails had the usual distortions from years of jacking / hoists, these were pulled back out, cleaned prepped and zinc primered, and for the fronts a 1.5mm plate tacked over the top. Holes will be drilled where the factory ones are to make sure they still drain water correctly. The car had been jacked up from the rail rears as well instead of the diff, so these were pretty ugly but looking perfect again now.
The sill panel seams and roadside tyre change jacking point that was buckled in have also been completely repaired. As of Friday night it should all be sitting in chip coat now!! Going to get a good bake first before it comes back down off the rotisserie just to really make sure everything is dried out, then work on the interior and panels will begin.
I have decided I am still going to get this thing screwed back together properly and then see from there if I can afford to keep it, don't know how I could possibly sell it though.
Some photos:
post-12551-0-52899000-1310942870_thumb.jpgpost-12551-0-29562600-1310942877_thumb.jpgpost-12551-0-64951300-1310942883_thumb.jpgpost-12551-0-72561100-1310942889_thumb.jpgpost-12551-0-96379600-1310942894_thumb.jpgpost-12551-0-07130600-1310942902_thumb.jpgpost-12551-0-91922100-1310942907_thumb.jpgpost-12551-0-29702200-1310942914_thumb.jpg
  • 1 month later...
So what is happening to the bus these days?
It has been put on slow-mo for now.
Bought Snowy's white 34 so getting out and about in that at the moment, entered in Targa High Country and Targa Tas next year so funds are all aimed at that at the moment.
It is however going back together an intended, with the Racepace motor and GT-SS turbos. It will be my tribute to the car that I love so much, and I will get it out to track days where there is minimal risk of damaging it's pristine state!
As much as I would love to drive it in a Targa event, it's kind of a better outcome 1) because it is going to be another one of Mick's works of art once finished that I couldn't bear to scratch, and 2) I can have some freedom with it from rules to do some crazy stuff down the track.. thinking v-cam, maybe some of these newer gen turbos coming through and possibly a larger capacity motor for an absolute response monster.
Should be in paint by the end of the year I would say, and Mick has kindly allowed me to re-assemble as much of it as I can at his shop once his bit is done.
  • 3 months later...
  • 3 months later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
