Spent yesterday on the car, mostly tidying up but got a few things done.
Removed these split HKS dumps ...
And replaced with this Midori setup. Biggest off the shelf dumps I could find, and the front pipes are pretty big compared to the JustJap ones I had on previously. Biggest in a two bolt flange.
They have really thought about the design on the Midori's, really easy to get to all the nuts as opposed to the HKS where I needed three different 12mm spanners for the nut at the back of the front dump.
Also rebuilt the clutch master with a new piston kit from Nissan. Really simple, two circlips, a good clean and check of the cylinder and back together with new bits.
Comparing pistons easy to see why it was leaking.
New piston in.
All back together and on the car.
BBQ fired up, triple level bbq burgers with the lot with an integrated egg / toasted bread centre layer and a couple of JD's - golden.
Have a spare full R34 battery cable / tray / fusebox setup so replicating the setup on the R32.
The riser into the engine bay doesn't quite work with the R32 so modified one of the brackets a bit to bolt to the same spot as the speedo cable. Will do some more work around here to make sure its locked down and doesnt interfere with anything else.
Rivnuts all the way.
Shape along the rail is identical. I lined up where the rail tapers out towards the front and the rest falls into place.
About the right amount of length up engine bay end.
Existing hole in the boot matches the standard R34 grommet.
Rear of the rail brackets fit in pretty well here too.
Up over the tailshaft. Bit different here so I may even go direct to the boot and size the cable down accordingly. No need for it to be longer than it needs to be.
How are you going to sit the positive end of the battery cable in the bay? My 33 has the battery under bonnet and I'm going to be putting in one of those cables like you are, just can't work out how I'm going to sit all the positive ends without it being dodgy or earthing out on the body.
I have the standard fuse / relay / distribution block spare from an R34 GTR so I am going to try to use that instead of the standard R32 GTR one you can see in the pics at the moment.
Sunk a good chunk of time in yesterday.
Finished off the power steering lines and pump in place.
Time to drop the engine in.
Triple check the rigging while stand still attached to make sure it holds up while hovering the engine over the car.
Engine in!
Looking good Paul. Now the fun bit.... the gearbox :D
Haha yeah looking forward to it .... I have a 500kg trolley that should help the cause a bit.
Need to get the flywheel machined first then the shenanigans begin.
  • 2 months later...
Getting things rolling on this again now I have recovered from everything else. Aiming to have it started within about the next 4 weeks.
Sammich plate is on, flywheel sent off for machining yesterday should be back today.
Clutch and gearbox should be back in over the next few days
Flywheel, clutch, gearbox and starter are in.
Freshly machined flywheel fitted and torqued up.
Then realised being a new engine it was missing the pilot / spigot bush in the end of the crank.
Picked one up and installed and flywheel back on.
Clutch on. Its an Xtreme unit I already had in the car, handled ~300rwkw so should still be up to the task.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
