I don't think she's cursed,,,nor does she need an exorcism,,,what she's needed was tender loving care which she has not seen for a while. She been getting plenty of it in the last 2 weeks let me tell you two boofheads. We started at about 2.30 and finished at 9.30,,,got all her under-belly done which was cool and for once I left happy.
I've left a message with the windscreen guy but I'll bet he's like almost everybody else and is still on holidays till next Monday. I'll ring him again on the 10th if I don't get a reply sooner.
Cheers
Neil.
The poor Yellow and Purple Beast is just a little stressed... With Uncy Dunc behind the wheel I know why too! HE'S A MADMAN! (And I love how he drives it!)
Neil, if you need a hand doing things with your beasty, lemme know.
I'm just starting to sell all my gear off... Going to start from a fresh base in 6 - 12 months time and build probably to the same standard as Duncs Yellow and Purple beasty.
so this wont be ready for MRA on the 30th? :D
That would be a big no unfortunately my good man.
World time attack I would think will be her 1st real hitout and I still won't have played silly buggers with horsepower.
Cheers
Neil.
Thanks for the kind offer Matt,,,look out mate we may just take you up on it.
Please don't tell me your considering a GTR cheater car,,,ha ha that rhymes.
Handles isn't a madman,,,he just owes one of Nissans finest. 21 years old and they are still handing current cars their arses.
Cheers
Neil.
Well in between Pete's HR31, waiting for machining, parts etc etc and the rain ive been stuffing around with Neil's car too, all be it slower than id like but trying to get the HR31 out of here sooner rather than latter, so I can finish my own GTiR.
Its no where near finished as yet, far from it actually but this is where its at.
Oh and a massive mention to my Fiance who has put up with me working on Pete's car for two weeks now and Neil's on and off this week, all while im meant to be on holidays doing nothing.....
Waiting for R33 full cage photos :)
Yea you and me both Michael,,, Gotta love the FIA's touring car standard intrusion bars instead of CAMS 3 bar ugly stuff. There wouldn't be to many cars running this quality,,,check this FPR pic,,,it's Paul Dumbrell's V8 supercar,,,very ugly.
Cheers
Neil.
Super taxi cages amuse me. We all have to adhere to a half door opening height for side intrusions even if the cage is homologated outside shedule J.
Yet have a go at how high they run their intrusions. I know why they do it and it makes perfect structural sence, but were not able to do it.
Same as the drop bar in the door opening. We have a few strict rules for door openings.
There are for and againsts when using the X intrsuions. They are actually way easier to fabricate than the bent bars beleive it or not.
what is the strength diference between the x bar that has 1 bar cut and welded around the other (like that v8 one), and the two bent bars with the gussett (like niels car, and WRC cages)
My logic would say a WRC would built to withstand bigger impacts, as side impacts are usually with a small diamiter tree (compated to being t boned by a car)
Cheers
Neil.
Feel free to take me up on it.
Just be aware I'm in Thailand until the 22nd of Jan... :D
And yes, alas I am considering a cheater car... Bang for buck, it's winning atm. But that decision is still a way off, the first thing to do is sell mine. It has to go unfortunately. It'll cost me twice as much to get it to Targa spec then starting from scratch.
What do you think Neil??
Its pretty similar to alot of other cages ive done like Ryan's
This one has the full roof X, different head support bars, intrusions and the windscreen supports.
The U type intrusions have a few advantages, the X bars obviously have a raised stress area where they are welded. The welded sections meet at fairly acute angles usually 50+ degrees, that leaves plenty of welded surface area, the welded area is just as strong as the original tube but the heat zones around the area can become a problem.
If they fail the X bars usually split open and create all sorts of nasty sharp edges etc not to mention the lack of protection.
The U bar obviously has no welded areas. It is also double tube diameter the entire length of the intrusion as opposed to the X bar which has a section usually an inch or so long that is only single bar protection.
For the U bars to fail they either need to spilt open (they are made from 750Mpa CDS as opposed to 350mpa), tear the welds off the main hoop and front legs (they are also tagged to the sill pannels and pillars where possible so not just relying on the hoop and leg welds in Neil's case) or finally they need to bend the legs and hoop, also needs to bend the hoop X, dash bar and roof supports to do so though...
So the U bars are stronger when done properly in double tube and they remove the chance of the X bars intersection failing.
The disavantage of the U bars is the additional work it requires. A normal X intrusion is pretty simple, straight tube two knotches, typically the cut tube is a 55-60 degree knotch welded together where it intersects and move on. sometimes fit two vertical gusset tubes if required.
The U bars need to be thought out alot more to make sure the bends line up and butt up against the other tube,it looks awful if the bends are different radius' or angles too so some though has to go into that too. I flatten the bend where they meet and MIG weld the two bars around the circumference, then make up two vertical supports from offcuts, finally cut the gusset plates and weld them in and with neil's car linish it all smooth so the whole gusset looks seamless to the intrusion.
Its easy to spend 3 hours on an intrusion bar. Worth the time though if the owner is willing to pay for it.
I rarely do U bars due to the extra time and cost involved. Not many people really bother either.
yeah guys windscreen man is the same as I was talking about. we go back about 10 years so was just helping him fill some orders. just been off on leave and computer free though so kind of fell off the map. back at work now though so neil if you've had no luck let me know and I will pick it up again. :)
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
