and it will bolt straight on for all of us GT30 framed turbo owners.
not so good on the pricing front for us GT35 owners. but given the power the GTX3076 should be capable of id even consider droping down in size for the added response with minimal power sacrifice, seeing as 2wd has enough trouble with traction as is :P
wouldnt you still be limited by the turbine housings tho?
This will be the interesting tale indeed.
As there are varying sizes it will certainly impact.
But when you think about it, the comp map won't change it will just be the characteristics (like restriction of a .63 limiting where in the map you can take the turbo).
Given results of the good ole .82 with the 3076, you could IW a 3071 IMO and probably smash 300rwkw, that would be fken awesome.
And for what, around 2k - would be virtually a bolt on job.
3076 performance @ a 3071 response, unquestionable IMO for a street car.
Then add E85 - Who would have thought a 3071 would be over 300rwkw, as that's potentially what will happen now on E85
damnit! after finishing with my current setup.. if i could get more power and more response... grrr! spoze be a ton cheaper because most of the tuning would be fine and all the other bits would suit from 3076r->gtx3076r... hmmm... next year....
3071 is easy 300 on e85 already...
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
